Fujifilm FinePix XP70 Front and Back Panel Replacement
  1. Fujifilm FinePix XP70 Front and Back Panel Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Power off the camera.
    • Leaving the camera on while removing presents the risk of electrical shock or permanent data loss.
  2. Fujifilm FinePix XP70 Front and Back Panel Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujifilm FinePix XP70 Front and Back Panel Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push down on the center button and turn the dial on the side counterclockwise to open the battery compartment.
  3. Fujifilm FinePix XP70 Front and Back Panel Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the orange tab towards the hinge to release the battery.
  4. Fujifilm FinePix XP70 Front and Back Panel Replacement, Front and Back Panel: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove one Phillips screw with a Phillips head 0 screwdriver
    • Remove one hex head screw with a hex 1.3 screwdriver bit.
  5. Fujifilm FinePix XP70 Front and Back Panel Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew two 4.0mm long hex head screws with a hex 1.3 screwdriver bit.
  6. Fujifilm FinePix XP70 Front and Back Panel Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew five 4.0mm screws with a Phillips head 0 screwdriver
  7. Fujifilm FinePix XP70 Front and Back Panel Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry the black bottom plate off using a plastic opening tool.
    • It is easier to start on the side of the open battery compartment.
  8. Fujifilm FinePix XP70 Front and Back Panel Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujifilm FinePix XP70 Front and Back Panel Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry the front plate off using a plastic opening tool.
    • It's recommended to start at the ridge on the top or bottom side.
  9. Fujifilm FinePix XP70 Front and Back Panel Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift off the front plate.
  10. Fujifilm FinePix XP70 Front and Back Panel Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujifilm FinePix XP70 Front and Back Panel Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujifilm FinePix XP70 Front and Back Panel Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry the back plate off with a plastic opening tool
Olivia A
crwdns2935283:010/24/16crwdne2935283:0
484 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S7-G3, Julie Spring 2017 crwdns2935289:0UMass Dartmouth, Team S7-G3, Julie Spring 2017crwdne2935289:0
UMASSD-JULIE-S17S7G3
Very helpful, do you know if you can buy these parts? I need the back part of the camera.
thank you
jg
Jose Gerardo Hernandez Montiel - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 461
