Frigidaire Side-By-Side Refrigerator Evaporator Fan Cover Removal
  1. Frigidaire Side-By-Side Refrigerator Evaporator Fan Cover Removal, Unplug your refrigerator: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. Frigidaire Side-By-Side Refrigerator Evaporator Fan Cover Removal, Remove the ice bin: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Frigidaire Side-By-Side Refrigerator Evaporator Fan Cover Removal, Remove the ice bin: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the freezer door.
    • Grasp the lower portion of the front of the ice bin.
    • Lift it slightly and pull it out toward the front of the refrigerator.
  3. Frigidaire Side-By-Side Refrigerator Evaporator Fan Cover Removal, Unfasten the ice maker: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Frigidaire Side-By-Side Refrigerator Evaporator Fan Cover Removal, Unfasten the ice maker: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Frigidaire Side-By-Side Refrigerator Evaporator Fan Cover Removal, Unfasten the ice maker: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • These screws are challenging to reach.
    • Use a 1/4" nut driver to remove the two screws securing the ice maker to the sidewall of the freezer compartment.
  4. Frigidaire Side-By-Side Refrigerator Evaporator Fan Cover Removal, Reposition the ice maker: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Frigidaire Side-By-Side Refrigerator Evaporator Fan Cover Removal, Reposition the ice maker: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the ice maker to the right and lower the front end to access the cable.
  5. Frigidaire Side-By-Side Refrigerator Evaporator Fan Cover Removal, Disconnect the icemaker: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Frigidaire Side-By-Side Refrigerator Evaporator Fan Cover Removal, Disconnect the icemaker: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Frigidaire Side-By-Side Refrigerator Evaporator Fan Cover Removal, Disconnect the icemaker: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the ice maker connector near the back of the freezer.
    • Squeeze the release tabs on the connector to release it, and pull it out to disconnect it.
    • You may need to use two hands to do this, one on the rear half and one on the front half of the connector.
    • You can support the ice maker on the ice bin support if you need both hands to disconnect it.
  6. Frigidaire Side-By-Side Refrigerator Evaporator Fan Cover Removal, Remove the ice maker: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Frigidaire Side-By-Side Refrigerator Evaporator Fan Cover Removal, Remove the ice maker: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the ice maker from the freezer compartment.
  7. Frigidaire Side-By-Side Refrigerator Evaporator Fan Cover Removal, Remove left side freezer drawer rail: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Frigidaire Side-By-Side Refrigerator Evaporator Fan Cover Removal, Remove left side freezer drawer rail: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a 1/4" nut driver to remove the two screws securing the left side freezer drawer rail.
    • Remove the drawer rail
  8. Frigidaire Side-By-Side Refrigerator Evaporator Fan Cover Removal, Unfasten auger motor assembly: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 1/4" nut driver to remove the two screws securing the auger motor assembly to the support brackets located in the rear of the freezer compartment.
  9. Frigidaire Side-By-Side Refrigerator Evaporator Fan Cover Removal, Reposition auger motor assembly: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Frigidaire Side-By-Side Refrigerator Evaporator Fan Cover Removal, Reposition auger motor assembly: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Frigidaire Side-By-Side Refrigerator Evaporator Fan Cover Removal, Reposition auger motor assembly: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the front end rail tie of the auger motor assembly to release it from the support brackets.
    • Lift the entire assembly upward and move it out toward the front of the freezer compartment.
    • Do not try to remove the entire auger motor assembly at this point. It is still connected by electrical cables to the rear of the freezer compartment.
    • Lower the assembly so it will be supported by the front portion of the assembly resting on a shelf located below. Avoid putting tension on the cable.
  10. Frigidaire Side-By-Side Refrigerator Evaporator Fan Cover Removal, Disconnect the auger motor assembly: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Frigidaire Side-By-Side Refrigerator Evaporator Fan Cover Removal, Disconnect the auger motor assembly: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Squeeze the release tab on the auger motor assembly cable and pull the connector out from the socket to disconnect it.
  11. Frigidaire Side-By-Side Refrigerator Evaporator Fan Cover Removal, Remove the auger motor assembly: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the auger motor assembly.
    • The assembly is quite unbalanced with a lot of weight to the rear, so hold it near the rear portion.
  12. Frigidaire Side-By-Side Refrigerator Evaporator Fan Cover Removal, Remove mounting brackets: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Frigidaire Side-By-Side Refrigerator Evaporator Fan Cover Removal, Remove mounting brackets: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a 1/4" nut driver to remove the two screws securing the left-hand auger motor assembly mounting bracket.
    • Repeat the step above for the right-hand bracket.
  13. Frigidaire Side-By-Side Refrigerator Evaporator Fan Cover Removal, Unfasten the upper evaporator cover.: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Frigidaire Side-By-Side Refrigerator Evaporator Fan Cover Removal, Unfasten the upper evaporator cover.: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a 1/4" nut driver to remove the five screws securing the upper evaporator panel.
    • Use a 1/4" nut driver to remove the two additional screws securing the upper and lower evaporator panels
  14. Frigidaire Side-By-Side Refrigerator Evaporator Fan Cover Removal, Remove the upper evaporator cover: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Frigidaire Side-By-Side Refrigerator Evaporator Fan Cover Removal, Remove the upper evaporator cover: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Frigidaire Side-By-Side Refrigerator Evaporator Fan Cover Removal, Remove the upper evaporator cover: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the hole in the upper evaporator cover to lift the upper evaporator cover off.
    • The sheet metal is sharp, and you should consider gloves to protect your hands. Work carefully.
  15. Frigidaire Side-By-Side Refrigerator Evaporator Fan Cover Removal, Unfasten the lower evaporator cover: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 1/4" nut driver to remove the two remaining screws securing the lower evaporator cover.
  16. Frigidaire Side-By-Side Refrigerator Evaporator Fan Cover Removal, Remove the lower evaporator cover: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Frigidaire Side-By-Side Refrigerator Evaporator Fan Cover Removal, Remove the lower evaporator cover: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Frigidaire Side-By-Side Refrigerator Evaporator Fan Cover Removal, Remove the lower evaporator cover: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the lower evaporator cover about 1/2" (13mm) to free it from the rear of the refrigerator.
    • Tilt the top of the lower evaporator cover toward the front of the fridge.
    • Remove the lower evaporator cover.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
Bill Gilbert
crwdns2935283:006/30/22crwdne2935283:0
37.849 crwdns2915208:0crwdne2915208:0
crwdns2935297:0261crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021.981crwdne2935297:0
crwdns2936753:030crwdne2936753:0 101
crwdns2942667:0crwdne2942667:0 369
