Frigidaire Refrigerator Run Capacitor Replacement
  1. Frigidaire Refrigerator Run Capacitor Replacement, Unplug your refrigerator: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. Frigidaire Refrigerator Run Capacitor Replacement, Unfasten the rear cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 1/4" nut driver to remove the four screws securing the rear cover to the refrigerator.
  3. Frigidaire Refrigerator Run Capacitor Replacement, Lift up the rear cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Frigidaire Refrigerator Run Capacitor Replacement, Lift up the rear cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Frigidaire Refrigerator Run Capacitor Replacement, Lift up the rear cover: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the rear cover until it is free of the tabs.
    • If your water supply line is in use, turn the supply valve off, and disconnect it at the connection on the refrigerator.
    • If the water supply hose is not used, pass it through the hole in the cover.
  4. Frigidaire Refrigerator Run Capacitor Replacement, Remove the cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the cover and set it aside.
  5. Frigidaire Refrigerator Run Capacitor Replacement, Loosen the condenser fan connector: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Frigidaire Refrigerator Run Capacitor Replacement, Loosen the condenser fan connector: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pry up the locking tab on the condenser fan connector.
  6. Frigidaire Refrigerator Run Capacitor Replacement, Disconnect the condenser fan connector: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Frigidaire Refrigerator Run Capacitor Replacement, Disconnect the condenser fan connector: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the condenser fan connector off of the start relay.
  7. Frigidaire Refrigerator Run Capacitor Replacement, Release the start relay: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Frigidaire Refrigerator Run Capacitor Replacement, Release the start relay: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Frigidaire Refrigerator Run Capacitor Replacement, Release the start relay: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of long nose pliers to grip the retaining clip near the attachment point on the start relay.
    • Pull the clip toward the compressor so the hook on the clip can be moved through the hole on the start relay.
    • Move the hook out of the hole to release the clip
  8. Frigidaire Refrigerator Run Capacitor Replacement, Remove the retaining clip: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once one side of the retaining clip is released, use your fingers to remove it from the mounting hole on the other side of the start relay.
    • Remove the clip and set it aside.
  9. Frigidaire Refrigerator Run Capacitor Replacement, Disconnect the start relay: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Frigidaire Refrigerator Run Capacitor Replacement, Disconnect the start relay: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Frigidaire Refrigerator Run Capacitor Replacement, Disconnect the start relay: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the start relay straight off the side of the compressor.
    • The compressor has three prongs on the side of it that fit into three holes on the start relay.
  10. Frigidaire Refrigerator Run Capacitor Replacement, Remove the run capacitor from the start relay: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Frigidaire Refrigerator Run Capacitor Replacement, Remove the run capacitor from the start relay: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Frigidaire Refrigerator Run Capacitor Replacement, Remove the run capacitor from the start relay: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the run capacitor off the start relay.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
Bill Gilbert
crwdns2935283:006/30/22crwdne2935283:0
37,700 crwdns2915208:0crwdne2915208:0
crwdns2935297:0261crwdne2935297:0
Staff
crwdns2931471:0120crwdne2931471:0
crwdns2935297:020,900crwdne2935297:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 75
