Framework Laptop 16" RAM Replacement
  1. Framework Laptop 16" RAM Replacement, Before you begin: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 16" RAM Replacement, Before you begin: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug all cables and fully shut down your laptop.
    • If your repair requires a spudger, a T5 Torx, or a Phillips screwdriver, you can use the included Framework screwdriver. Whichever works best for you!
    • Framework recommends that you put your laptop into battery disconnect mode in the BIOS whenever removing the battery. Read how to do that here.
    • To disable this mode, click here.
  2. Framework Laptop 16" RAM Replacement, Unlock the Input Modules: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Framework Laptop 16" RAM Replacement, Unlock the Input Modules: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Framework Laptop 16" RAM Replacement, Unlock the Input Modules: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingernail to pull out the two Input Module latches and unlock them.
    • The latch will show red if it's unlocked.
  3. Framework Laptop 16" RAM Replacement, Remove the touchpad spacers: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Framework Laptop 16" RAM Replacement, Remove the touchpad spacers: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Framework Laptop 16" RAM Replacement, Remove the touchpad spacers: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to slide the touchpad spacer toward the bottom edge of the laptop and unclip it.
    • If you're having trouble, check if the corresponding Input Module latch is properly unlocked.
    • Lift the touchpad spacer off the laptop and remove it.
  4. Framework Laptop 16" RAM Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Repeat the same procedure for the other touchpad spacer.
  5. Framework Laptop 16" RAM Replacement, Remove the touchpad: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Framework Laptop 16" RAM Replacement, Remove the touchpad: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Framework Laptop 16" RAM Replacement, Remove the touchpad: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to slide the touchpad toward the bottom edge of the laptop and disconnect it.
    • If you're having trouble, check if the Input Module latches are properly unlocked.
    • Lift the touchpad and remove it.
    • During reassembly, perform the following:
    • Place the touchpad flat on its cutout so its clips are properly aligned.
    • Press the touchpad down and slide it into place so it lines up evenly with the bottom edge of the laptop.
  6. Framework Laptop 16" RAM Replacement, Remove the keyboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Framework Laptop 16" RAM Replacement, Remove the keyboard: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Framework Laptop 16" RAM Replacement, Remove the keyboard: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The keyboard is held in place with strong magnets. Apply gradually increasing force to avoid having the keyboard violently eject.
    • Grip the two pull tabs along the bottom of the keyboard.
    • Lift the pull tabs until the keyboard magnets release.
    • Remove the keyboard.
    • During reassembly, make sure the keyboard is seated properly on its alignment pegs and sits evenly with the edges of the laptop.
  7. Framework Laptop 16" RAM Replacement, Remove the numpad: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Framework Laptop 16" RAM Replacement, Remove the numpad: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Framework Laptop 16" RAM Replacement, Remove the numpad: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The numpad is held in place with strong magnets. Apply gradually increasing force to avoid having the numpad violently eject.
    • Grip the pull tab at the bottom of the numpad.
    • Lift the pull tab until the numpad magnets release.
    • Remove the numpad.
    • During reassembly, make sure the numpad is seated properly on its alignment pegs and sits flush with the edges of the laptop.
  8. Framework Laptop 16" RAM Replacement, Disconnect the midframe cable: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 16" RAM Replacement, Disconnect the midframe cable: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grip the black pull tab on the midframe cable press connector.
    • Lift up to disconnect the midframe cable.
  9. Framework Laptop 16" RAM Replacement, Loosen the midframe screws: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 16" RAM Replacement, Loosen the midframe screws: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The midframe screws are ordered from 2–17 (number 1 is the press connector). You don't have to follow the order, but you can use it to help keep track of the screws you've loosened.
    • Use a T5 Torx screwdriver to loosen the 16 captive screws securing the midframe.
    • During reassembly, follow the order (starting with 2) to reinstall the screws across the midframe evenly.
  10. Framework Laptop 16" RAM Replacement, Remove the midframe: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 16" RAM Replacement, Remove the midframe: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingernail to lift the bottom edge of the midframe enough to grip it with your fingers.
  11. Framework Laptop 16" RAM Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 16" RAM Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the midframe off the laptop and remove it.
    • During reassembly, make sure the midframe sits evenly on its alignment pegs before tightening the screws.
  12. Framework Laptop 16" RAM Replacement, Loosen the battery screws: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 16" RAM Replacement, Loosen the battery screws: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T5 Torx screwdriver to loosen the three captive screws securing the battery.
  13. Framework Laptop 16" RAM Replacement, Remove the battery: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Framework Laptop 16" RAM Replacement, Remove the battery: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Framework Laptop 16" RAM Replacement, Remove the battery: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grip the black pull tab at the top of the battery.
    • Lift the pull tab to disconnect the battery connector.
    • Remove the battery.
  14. Framework Laptop 16" RAM Replacement, Remove the RAM: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Framework Laptop 16" RAM Replacement, Remove the RAM: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Framework Laptop 16" RAM Replacement, Remove the RAM: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push the two metal arms on each side of the RAM stick outward until they disengage and the stick pops up at a shallow angle.
    • Repeat for the other RAM stick.
  15. Framework Laptop 16" RAM Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Framework Laptop 16" RAM Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Framework Laptop 16" RAM Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the RAM stick out of its socket and remove it.
    • During reassembly, insert the RAM sticks into their sockets at a slight downward angle, then push down firmly until both metal arms lock the sticks in place.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Alex Diaz-Kokaisl
crwdns2935283:001/16/22crwdne2935283:0
174,631 crwdns2915208:0crwdne2915208:0
crwdns2935297:0798crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:022,014crwdne2935297:0
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 92
crwdns2942667:0crwdne2942667:0 1,043
