crwdns2918348:0crwdne2918348:0
crwdns2942335:0crwdne2942335:0
crwdns2959928:0crwdne2959928:0 ↓Use this guide to remove and replace the one or both of the Expansion Bay Shell Fans in your Framework Laptop 16.
Unplug all cables and fully shut down your laptop.
Use your fingernail to pull out the two Input Module latches and unlock them.
Use your fingers to slide the Touchpad Spacer toward the bottom edge of the laptop and unclip it.
Lift the Touchpad Spacer off the laptop and remove it.
Repeat the same procedure for the other touchpad spacer.
Use your fingers to slide the Touchpad Module toward the bottom edge of the laptop and disconnect it.
Lift the Touchpad Module and remove it.
Grip the two pull tabs along the bottom of the keyboard and lift until its magnets release.
Remove the keyboard.
Grip the pull tab at the bottom of the Input Module and lift until its magnets release.
Remove the Input Module.
Repeat for any remaining Input Modules.
Lift the interposer door by its black pull tab and let it rest upright.
Use your Framework Screwdriver to loosen the three captive T5 Torx screws securing the interposer.
Lift the interposer by its pull tab and remove it.
Use your Framework Screwdriver to loosen the two captive T5 Torx screws securing the Expansion Bay Shell.
Close the interposer door before continuing.
Close your laptop and flip it over.
Slide the Expansion Bay Shell out of the laptop and remove it.
Use the flat end of your Framework Screwdriver, or a clean fingernail, to lift up and release the locking tab on the fan ZIF connectors.
Use your fingers to grip the brown pull tab and slide the fan cable straight out of its socket.
Use your Framework Screwdriver to loosen the four captive Torx T5 screws securing the fan.
Use one hand to press the fan cable flat to the module.
Use your other hand to pull the fan out of its housing, making sure to thread the cable through its slot.
Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
Place the fan onto the Expansion Bay Shell, making sure to thread the cable through its slot.
Use your Framework Screwdriver to tighten the four captive Torx T5 screws securing the fan.
Use your fingers to grip the brown pull tab and slide the fan cable straight into its socket.
Use the flat end of your Framework Screwdriver, or a clean fingernail, to press down the locking tab on the right fan ZIF connector.
Use your other hand to pull the fan out of its housing, making sure to thread the cable though its slot.
Align the Expansion Bay Shell with its slot in the laptop.
There should be no gaps between the laptop and the shell when it's installed correctly.
While keeping the shell level with the laptop, slide it into its slot.
Flip over the laptop and open it.
Use your Framework Screwdriver to tighten the two captive T5 Torx screws securing the Expansion Bay Shell.
Place the interposer over its spot between the Mainboard and the Expansion Bay.
Use your Framework Screwdriver to tighten the three captive T5 Torx screws securing the interposer.
Close the interposer door.
Align the top edge of the Input Module with the top edge of the laptop.
Lay the Input Module on the laptop and let the magnets pull the keyboard into place
Align the top edge of the keyboard with the top edge of the laptop.
Lay the keyboard on the laptop and let the magnets pull the keyboard into place
Place the Touchpad Module flat on its cutout so its clips are properly aligned.
Press the Touchpad Module down and slide it into place so it lines up evenly with the bottom edge of the laptop.
Place the Touchpad Spacer over its spot on the laptop with the bottom edge overhanging slightly.
Slide the Touchpad Spacer towards the top of the laptop to secure it.
Repeat the same procedure for the other Touchpad Spacer.
You finished fixing your Framework Laptop!
If you need help, contact Framework support.
