Framework Laptop 12 Mainboard Installation
crwdns2862623:0crwdne2862623:0
crwdns2948751:0crwdne2948751:0
  1. Framework Laptop 12 Mainboard Installation, Install the Mainboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Mainboard Installation, Install the Mainboard: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully lay the Mainboard in the laptop.
    • Use the two alignment pins to help align the Mainboard to the laptop.
    • Be careful not to trap the webcam or display cables under the Mainboard as you set it in place.
  2. Framework Laptop 12 Mainboard Installation: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Framework Screwdriver to tighten the five captive T5 Torx screws to secure the Mainboard.
    • Tighten the screws until they're snug. Don't over-tighten them, or you may strip the screws.
  3. Framework Laptop 12 Mainboard Installation: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Mainboard Installation: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to grab the display cable by its orange tab.
    • Align and press the display cable straight down onto its connector.
  4. Framework Laptop 12 Mainboard Installation: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Mainboard Installation: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to grab the webcam cable by its orange tab.
    • Align and press the webcam cable straight down onto its connector.
  5. Framework Laptop 12 Mainboard Installation, Install the Wi-Fi card: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Mainboard Installation, Install the Wi-Fi card: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to carefully move the Wi-Fi card over the Mainboard.
  6. Framework Laptop 12 Mainboard Installation: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Mainboard Installation: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Hold the Wi-Fi card by its edges. Don't touch the gold contacts with your fingers. If you do, wipe the contacts with a clean, lint-free cloth to remove any finger oils.
    • Align the Wi-Fi card's gold contacts and notch with the socket on the Mainboard.
    • Insert the Wi-Fi card into the socket at a shallow angle. The gold contacts should mostly be covered by the socket.
    • If the clear Wi-Fi card bracket or antenna cables got disconnected during the repair, go to the next step. If they're still attached, skip down three steps.
  7. Framework Laptop 12 Mainboard Installation, Reconnect a disconnected antenna cable: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Mainboard Installation, Reconnect a disconnected antenna cable: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Mainboard Installation, Reconnect a disconnected antenna cable: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Follow the next two steps if an antenna cable disconnected from the Wi-Fi card.
    • Hold the Wi-Fi card down with your finger.
    • Position the black antenna cable connector over the left Wi-Fi card's coaxial socket.
    • Tweezers can help position the connector.
    • Use your finger to press the connector into place. You should feel a faint click, and the cable will stay attached to the socket by itself.
    • These connectors are very delicate! If the connector doesn't feel like it's clicking in place, reposition the connector and try again.
    • Repeat the procedure with the white antenna cable.
  8. Framework Laptop 12 Mainboard Installation: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Mainboard Installation: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the Wi-Fi bracket over the top edge of the Wi-Fi card.
  9. Framework Laptop 12 Mainboard Installation, Tighten the Wi-Fi card screw: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Framework Screwdriver to tighten the captive T5 Torx screw to secure the Wi-Fi card.
Arthur Shi
crwdns2935283:001/03/18crwdne2935283:0
314,810 crwdns2915208:0crwdne2915208:0
crwdns2935297:0729crwdne2935297:0
crwdns2942667:0crwdne2942667:0 35
