Framework Laptop 12 Hinges Replacement
  1. Framework Laptop 12 Hinges Replacement, Power down your laptop: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinges Replacement, Power down your laptop: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinges Replacement, Power down your laptop: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before you begin repairs, unplug your laptop and shut it down from the operating system. This ensures that the laptop isn't in standby/suspend mode.
    • The indicator LEDs along the edges should be unlit. The laptop should be silent.
    • If you accidentally turn on the laptop during repair, hold the power button down for 10 seconds to shut it down.
    • Make sure your Framework Screwdriver has the T5 Torx bit (labeled as T-5) facing outwards. If it's not, pull the bit out and flip it.
  2. Framework Laptop 12 Hinges Replacement, Set your laptop down: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Set your Framework Laptop face-down on a clean work surface.
  3. Framework Laptop 12 Hinges Replacement, Remove the Expansion Cards: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinges Replacement, Remove the Expansion Cards: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to flip the two Expansion Card latches (one for each side) into the unlocked position.
    • The latches display a red bar when they're unlocked.
  4. Framework Laptop 12 Hinges Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinges Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinges Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grip the lip of an Expansion Card with your fingers.
    • Pull the Expansion Card out of its slot and remove it.
    • If you have trouble pulling the Expansion Card out, you can also use the flat end of your Framework Screwdriver to push against the lip.
    • Repeat this procedure to remove all remaining Expansion Cards.
  5. Framework Laptop 12 Hinges Replacement, Loosen the bottom screws: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinges Replacement, Loosen the bottom screws: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your Framework Screwdriver to fully loosen the eight captive T5 Torx screws on the bottom of your laptop.
    • Most screws in your Framework Laptop (including these) are captive—they're designed to stay in place after you loosen them.
    • Your laptop comes with a spare set of screws in the frame above the battery. Be careful—the replacement screws aren't captive.
  6. Framework Laptop 12 Hinges Replacement, Flip your laptop over: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip your laptop face-up on your work surface.
  7. Framework Laptop 12 Hinges Replacement, Open your laptop: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinges Replacement, Open your laptop: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the laptop lid so that both the screen and the base lie flat on your work surface.
  8. Framework Laptop 12 Hinges Replacement, Remove the Input Cover: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinges Replacement, Remove the Input Cover: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinges Replacement, Remove the Input Cover: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to grip the Input Cover in the hinge cutouts.
    • Lift upwards to swing the Input Cover up from the base of the laptop.
    • You may feel resistance from the magnets. If the cover feels like it's snagged, check that you've fully loosened the screws on the bottom of your laptop.
    • Remove the Input Cover.
  9. Framework Laptop 12 Hinges Replacement, Loosen the battery screws: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Framework Screwdriver to loosen the six captive T5 Torx screws securing the battery.
  10. Framework Laptop 12 Hinges Replacement, Disconnect the battery: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinges Replacement, Disconnect the battery: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the orange battery tab with your fingers and lift straight up to disconnect the battery.
    • The battery connector can be tight, requiring some force. If it feels like part of the battery won't come up, check that the battery screws are fully loosened.
  11. Framework Laptop 12 Hinges Replacement, Remove the battery: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinges Replacement, Remove the battery: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift and remove the battery from the laptop.
  12. Framework Laptop 12 Hinges Replacement, Loosen the Audio Board screw: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Framework Screwdriver to loosen the captive T5 Torx screw securing the Audio Board along the left edge of the laptop.
  13. Framework Laptop 12 Hinges Replacement, Remove the Audio Board: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinges Replacement, Remove the Audio Board: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinges Replacement, Remove the Audio Board: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to lift the right edge of the Audio Board and pull it out of its recess.
    • Remove the Audio Board.
  14. Framework Laptop 12 Hinges Replacement, Loosen the Power Button Board screw: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Framework Screwdriver to loosen the captive T5 Torx screw securing the Power Button Board (labeled "Power Board").
  15. Framework Laptop 12 Hinges Replacement, Remove the Power Button Board: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinges Replacement, Remove the Power Button Board: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to lift and remove the Power Button Board.
  16. Framework Laptop 12 Hinges Replacement, Loosen the Wi-Fi card screw: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Framework Screwdriver to loosen the captive T5 Torx screw securing the Wi-Fi card bracket.
    • The Wi-Fi card will pop up slightly when you unfasten the bracket.
  17. Framework Laptop 12 Hinges Replacement, Remove the Wi-Fi card bracket: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinges Replacement, Remove the Wi-Fi card bracket: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the Wi-Fi card bracket with your fingers and slide it off the top of the Wi-Fi card.
    • Remove the bracket and store it in a safe location for reassembly.
  18. Framework Laptop 12 Hinges Replacement, Disconnect the antenna cables: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinges Replacement, Disconnect the antenna cables: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinges Replacement, Disconnect the antenna cables: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The Wi-Fi card has two delicate coaxial cable connectors. Follow this step carefully to avoid damaging them.
    • Press and hold the Wi-Fi card down with your finger.
    • Slide the flat edge of your Framework Screwdriver under the white antenna cable, as close to the metal head as possible.
    • If you have angled tweezers, slide one arm of a pair of tweezers under the antenna connector, as close to the metal head as possible.
    • Gently lift the connector straight up to disconnect the white antenna cable.
    • Repeat the procedure with the black antenna cable.
  19. Framework Laptop 12 Hinges Replacement, Remove the Wi-Fi card: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinges Replacement, Remove the Wi-Fi card: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the Wi-Fi card by the edges and pull it out of its socket.
    • Remove the Wi-Fi card.
  20. Framework Laptop 12 Hinges Replacement, Disconnect the webcam cable: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinges Replacement, Disconnect the webcam cable: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to grab the orange tab on the webcam cable, located near the left hinge.
    • Lift straight up to disconnect the cable.
  21. Framework Laptop 12 Hinges Replacement, Disconnect the display cable: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinges Replacement, Disconnect the display cable: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to grab the orange tab on the display cable, located near the right hinge.
  22. Framework Laptop 12 Hinges Replacement, Loosen the Mainboard screws: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Framework Screwdriver to loosen the five captive T5 Torx screws securing the Mainboard.
    • These screws are also physically marked with an orange ring on the Mainboard.
  23. Framework Laptop 12 Hinges Replacement, Remove the Mainboard: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinges Replacement, Remove the Mainboard: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Make sure you've removed all Expansion Cards. Installed cards will hold the Mainboard in place.
    • Use your fingers to grab the Mainboard by its edges.
    • Lift and remove the Mainboard.
  24. Framework Laptop 12 Hinges Replacement, Unthread the antenna cable: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinges Replacement, Unthread the antenna cable: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to lift the black plastic loop securing the antenna cable, near the heat vents by the left hinge.
  25. Framework Laptop 12 Hinges Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinges Replacement: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to lift and guide the antenna cable out of the frame channel.
  26. Framework Laptop 12 Hinges Replacement, Unthread the webcam cable: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinges Replacement, Unthread the webcam cable: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to gently lift the webcam cable out of its plastic channel.
  27. Framework Laptop 12 Hinges Replacement, Disconnect the Top Cover: crwdns2935265:027crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinges Replacement, Disconnect the Top Cover: crwdns2935265:027crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your Framework Screwdriver to remove the six (three per hinge) 4.5 mm‑long T5 Torx screws securing the two hinges.
    • These screws are not captive. Store them in a safe location for reassembly.
  28. Framework Laptop 12 Hinges Replacement: crwdns2935265:028crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinges Replacement: crwdns2935265:028crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinges Replacement: crwdns2935265:028crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to lift the hinges over the Bottom Cover lip.
    • Separate the Top Cover from the Bottom Cover.
  29. Framework Laptop 12 Hinges Replacement, Remove the Display Cover: crwdns2935265:029crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinges Replacement, Remove the Display Cover: crwdns2935265:029crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The Display Cover is held in place with magnets along its top edge and clips along its remaining edges.
    • Use the flat end of your Framework Screwdriver to pry up the right edge of the Display Cover.
  30. Framework Laptop 12 Hinges Replacement: crwdns2935265:030crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinges Replacement: crwdns2935265:030crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide your fingers under the top edge of the Display Cover to release it from the laptop.
  31. Framework Laptop 12 Hinges Replacement: crwdns2935265:031crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the Display Cover.
  32. Framework Laptop 12 Hinges Replacement, Bend the hinges up: crwdns2935265:032crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinges Replacement, Bend the hinges up: crwdns2935265:032crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinges Replacement, Bend the hinges up: crwdns2935265:032crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to twist the right hinge plate until it's flipped on top of the display.
    • The stiff hinge can be difficult to twist. Wear some work gloves, or use a cloth to help get a better grip.
  33. Framework Laptop 12 Hinges Replacement: crwdns2935265:033crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinges Replacement: crwdns2935265:033crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinges Replacement: crwdns2935265:033crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Twist the left hinge plate until it's flipped on top of the display.
  34. Framework Laptop 12 Hinges Replacement, Release the cables from the hinges: crwdns2935265:034crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinges Replacement, Release the cables from the hinges: crwdns2935265:034crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to grab the two cables coming out of the left hinge.
    • Pull gently to pop out the black cable clip and release the cables.
  35. Framework Laptop 12 Hinges Replacement: crwdns2935265:035crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinges Replacement: crwdns2935265:035crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Repeat the procedure on the right hinge to release the cables.
  36. Framework Laptop 12 Hinges Replacement, Twist the hinge plates down: crwdns2935265:036crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinges Replacement, Twist the hinge plates down: crwdns2935265:036crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinges Replacement, Twist the hinge plates down: crwdns2935265:036crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to twist both hinge plates back down so they lay flat on your work surface.
  37. Framework Laptop 12 Hinges Replacement, Remove the display screws: crwdns2935265:037crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Framework Screwdriver to remove the four 3.3 mm‑long T5 Torx screws securing the display to the Top Cover.
  38. Framework Laptop 12 Hinges Replacement, Slide the display down: crwdns2935265:038crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinges Replacement, Slide the display down: crwdns2935265:038crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to hold the bottom edge of the Top Cover in place.
    • Insert the bit end of your Framework Screwdriver into the small hole on the display, below the Framework logo.
    • Slide the display down towards the hinge edge to release the tabs holding the top edge of the display in place.
  39. Framework Laptop 12 Hinges Replacement, Lift the display: crwdns2935265:039crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinges Replacement, Lift the display: crwdns2935265:039crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to lift the top edge of the display from the Top Cover.
  40. Framework Laptop 12 Hinges Replacement, Remove the display: crwdns2935265:040crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinges Replacement, Remove the display: crwdns2935265:040crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift and remove the display from the Top Cover.
  41. Framework Laptop 12 Hinges Replacement, Remove the hinge screws: crwdns2935265:041crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinges Replacement, Remove the hinge screws: crwdns2935265:041crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your Framework Screwdriver to remove the four (two per hinge) 2.5 mm‑long T5 Torx screws securing the two hinges to the Top Cover.
  42. Framework Laptop 12 Hinges Replacement, Remove the hinges: crwdns2935265:042crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinges Replacement, Remove the hinges: crwdns2935265:042crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift and remove both hinges from the Top Cover.
  43. Framework Laptop 12 Hinges Replacement, Disassembly complete: crwdns2935265:043crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
  44. Framework Laptop 12 Hinges Replacement, Install the hinges: crwdns2935265:044crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinges Replacement, Install the hinges: crwdns2935265:044crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinges Replacement, Install the hinges: crwdns2935265:044crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lay both hinges in place in the Top Cover.
    • Use the alignment pins to help position each hinge in place.
  45. Framework Laptop 12 Hinges Replacement: crwdns2935265:045crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinges Replacement: crwdns2935265:045crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Make sure both antenna cables are properly routed in the Top Cover and tucked into the hinges, as shown in the images.
  46. Framework Laptop 12 Hinges Replacement: crwdns2935265:046crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinges Replacement: crwdns2935265:046crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your Framework Screwdriver to install the four 2.5 mm‑long T5 Torx screws to secure the two hinges to the Top Cover.
    • Make sure to install these screws in the marked locations. There are additional screw holes on the hinges that are not for these screws.
  47. Framework Laptop 12 Hinges Replacement, Install the display: crwdns2935265:047crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinges Replacement, Install the display: crwdns2935265:047crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinges Replacement, Install the display: crwdns2935265:047crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lay the display in place in the Top Cover, such that the top edge of the display is slightly below the top edge of the Top Cover.
  48. Framework Laptop 12 Hinges Replacement: crwdns2935265:048crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinges Replacement: crwdns2935265:048crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinges Replacement: crwdns2935265:048crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to slide the display upwards to latch the tabs on the top edge of the display.
    • The top edge shouldn't have any gaps when the display's in place.
  49. Framework Laptop 12 Hinges Replacement, Install the display screws: crwdns2935265:049crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Framework Screwdriver to install the four 3.3 mm‑long T5 Torx screws to secure the display to the Top Cover.
    • Tighten the screws until they're snug. Don't over-tighten them, or you may damage the screw tabs.
  50. Framework Laptop 12 Hinges Replacement: crwdns2935265:050crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinges Replacement: crwdns2935265:050crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinges Replacement: crwdns2935265:050crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to twist both hinge plates so they're flipped over the display.
  51. Framework Laptop 12 Hinges Replacement: crwdns2935265:051crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinges Replacement: crwdns2935265:051crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinges Replacement: crwdns2935265:051crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the cable clip around the right hinge cables, where they were bent from being inserted into the hinge.
    • Use your fingers to press the clip into the hinge to secure the cables.
  52. Framework Laptop 12 Hinges Replacement: crwdns2935265:052crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinges Replacement: crwdns2935265:052crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Repeat the procedure on the left hinge to secure the left cables.
  53. Framework Laptop 12 Hinges Replacement: crwdns2935265:053crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinges Replacement: crwdns2935265:053crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Make sure both cable clips are fully inserted into the hinges, so that they won't be snagged when the hinges pivot.
  54. Framework Laptop 12 Hinges Replacement: crwdns2935265:054crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinges Replacement: crwdns2935265:054crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinges Replacement: crwdns2935265:054crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to twist both hinge plates so that they lay flat on your work surface.
  55. Framework Laptop 12 Hinges Replacement: crwdns2935265:055crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinges Replacement: crwdns2935265:055crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinges Replacement: crwdns2935265:055crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lay the Display Cover in place below the display.
    • Use your finger to press along the length of the Display Cover to snap it onto the laptop.
  56. Framework Laptop 12 Hinges Replacement, Reconnect the Top Cover: crwdns2935265:056crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinges Replacement, Reconnect the Top Cover: crwdns2935265:056crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinges Replacement, Reconnect the Top Cover: crwdns2935265:056crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to lift the Top Cover hinges over the Bottom Cover lip.
    • Lay the hinges in place in the Bottom Cover.
    • Use the plastic alignment pins to align each hinge in place.
  57. Framework Laptop 12 Hinges Replacement: crwdns2935265:057crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinges Replacement: crwdns2935265:057crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your Framework Screwdriver to install the six 4.5 mm‑long T5 Torx screws securing the two hinges.
  58. Framework Laptop 12 Hinges Replacement: crwdns2935265:058crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinges Replacement: crwdns2935265:058crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to gently press the webcam cable into its plastic channel.
  59. Framework Laptop 12 Hinges Replacement: crwdns2935265:059crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinges Replacement: crwdns2935265:059crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers and your Framework Screwdriver to carefully press and guide the black antenna cable back into its channel.
    • Zoom in on the second image to see how the antenna cable sits in its channel.
  60. Framework Laptop 12 Hinges Replacement: crwdns2935265:060crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinges Replacement: crwdns2935265:060crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press the black loop over the antenna cable and onto the Bottom Cover. If it doesn't stick, use a bit of thin double-sided tape to hold it down.
  61. Framework Laptop 12 Hinges Replacement, Install the Mainboard: crwdns2935265:061crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinges Replacement, Install the Mainboard: crwdns2935265:061crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully lay the Mainboard in the laptop.
    • Use the two alignment pins to help align the Mainboard to the laptop.
    • Be careful not to trap the webcam, display, and antenna cables under the Mainboard as you set it in place.
  62. Framework Laptop 12 Hinges Replacement: crwdns2935265:062crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Framework Screwdriver to tighten the five captive T5 Torx screws to secure the Mainboard.
  63. Framework Laptop 12 Hinges Replacement: crwdns2935265:063crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinges Replacement: crwdns2935265:063crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Align and press the display cable straight down onto its connector.
  64. Framework Laptop 12 Hinges Replacement: crwdns2935265:064crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinges Replacement: crwdns2935265:064crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Align and press the webcam cable straight down onto its connector.
  65. Framework Laptop 12 Hinges Replacement, Install the Wi-Fi card: crwdns2935265:065crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinges Replacement, Install the Wi-Fi card: crwdns2935265:065crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Hold the Wi-Fi card by its edges. Don't touch the gold contacts with your fingers. If you do, wipe the contacts with a clean, lint-free cloth to remove any finger oils.
    • Align the Wi-Fi card's gold contacts and notch with the socket on the Mainboard.
    • Insert the Wi-Fi card into the socket at a shallow angle. The gold contacts should mostly be covered by the socket.
    • The Wi-Fi card fits into the socket in one orientation. If it doesn't fit, try flipping the module.
  66. Framework Laptop 12 Hinges Replacement: crwdns2935265:066crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinges Replacement: crwdns2935265:066crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinges Replacement: crwdns2935265:066crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Hold the Wi-Fi card down with your finger.
    • Position the black antenna cable connector over the left Wi-Fi card's coaxial socket.
    • Tweezers can help position the connector.
    • Use your finger to press the connector into place. You should feel a faint click, and the cable will stay attached to the socket by itself.
    • These connectors are very delicate! If the connector doesn't feel like it's clicking in place, reposition the connector and try again.
    • Repeat the procedure with the white antenna cable.
  67. Framework Laptop 12 Hinges Replacement: crwdns2935265:067crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinges Replacement: crwdns2935265:067crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the Wi-Fi bracket over the top edge of the Wi-Fi card.
  68. Framework Laptop 12 Hinges Replacement: crwdns2935265:068crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Framework Screwdriver to tighten the captive T5 Torx screw to secure the Wi-Fi card.
  69. Framework Laptop 12 Hinges Replacement, Install the Power Button Board: crwdns2935265:069crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinges Replacement, Install the Power Button Board: crwdns2935265:069crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinges Replacement, Install the Power Button Board: crwdns2935265:069crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to lay the Power Button Board in place.
    • Use the two plastic pins on the laptop to align the Power Button Board.
  70. Framework Laptop 12 Hinges Replacement: crwdns2935265:070crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Framework Screwdriver to tighten the captive T5 Torx screw to secure the Power Button Board.
    • Tighten the screw until it's snug. Don't over-tighten it, or you may strip the screw.
  71. Framework Laptop 12 Hinges Replacement, Install the Audio Board: crwdns2935265:071crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinges Replacement, Install the Audio Board: crwdns2935265:071crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinges Replacement, Install the Audio Board: crwdns2935265:071crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the Audio Board into the laptop at an angle to help align the headphone jack.
    • Use the two plastic alignment pins on the laptop to help with final alignment.
  72. Framework Laptop 12 Hinges Replacement: crwdns2935265:072crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Framework Screwdriver to tighten the captive T5 Torx screw to secure the Audio Board.
  73. Framework Laptop 12 Hinges Replacement, Install the battery: crwdns2935265:073crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lay the battery in its recess in the laptop.
  74. Framework Laptop 12 Hinges Replacement: crwdns2935265:074crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinges Replacement: crwdns2935265:074crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your finger to push the battery down near its connector to reconnect it.
  75. Framework Laptop 12 Hinges Replacement: crwdns2935265:075crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Framework Screwdriver to tighten the six captive T5 Torx screws to secure the battery.
    • Tighten the screws until they're snug. Don't over-tighten them, or you may strip the screws.
  76. Framework Laptop 12 Hinges Replacement, Install the Input Cover: crwdns2935265:076crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinges Replacement, Install the Input Cover: crwdns2935265:076crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinges Replacement, Install the Input Cover: crwdns2935265:076crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Angle the bottom edge of the Input Cover towards the base of the laptop.
    • Align and insert the bottom edge of the Input Cover into the base of the laptop.
    • Make sure the slots along the bottom edge of the Input Cover slide into the tabs in the base.
    • Lower the Input Cover's top edge onto the laptop until the magnets snap it in place.
    • Make sure the Input Cover sits neatly within the laptop frame and no corners are popping up.
  77. Framework Laptop 12 Hinges Replacement: crwdns2935265:077crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinges Replacement: crwdns2935265:077crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Close the laptop lid.
    • Flip your laptop face-down on a clean work surface.
  78. Framework Laptop 12 Hinges Replacement, Tighten the bottom screws: crwdns2935265:078crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinges Replacement, Tighten the bottom screws: crwdns2935265:078crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your Framework Screwdriver to tighten the eight captive T5 Torx screws on the bottom of your laptop.
  79. Framework Laptop 12 Hinges Replacement, Install the Expansion Cards: crwdns2935265:079crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinges Replacement, Install the Expansion Cards: crwdns2935265:079crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinges Replacement, Install the Expansion Cards: crwdns2935265:079crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide each Expansion Card into its Expansion Card slot.
  80. Framework Laptop 12 Hinges Replacement, Lock the Expansion Card slots: crwdns2935265:080crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinges Replacement, Lock the Expansion Card slots: crwdns2935265:080crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If there's a red bar showing under either Expansion Card latch, use your finger to flip the latch and lock the Expansion Card into its slot.
    • Locking the Expansion Card slots helps keep the cards in place when you unplug cables from them.
You finished fixing your Framework Laptop!
If you need help, contact Framework support.
Arthur Shi
crwdns2935283:001/03/18crwdne2935283:0
306.331 crwdns2915208:0crwdne2915208:0
crwdns2935297:0691crwdne2935297:0
Guide Team crwdns2935289:0Guide Teamcrwdne2935289:0
Staff
crwdns2931471:010crwdne2931471:0
crwdns2935297:015.323crwdne2935297:0
crwdns2936753:030crwdne2936753:0 33
crwdns2942667:0crwdne2942667:0 277
