Framework Laptop 12 Fan Replacement
  1. Framework Laptop 12 Fan Replacement, Power down your laptop: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Fan Replacement, Power down your laptop: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Fan Replacement, Power down your laptop: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before you begin repairs, unplug your laptop and shut it down from the operating system. This ensures that the laptop isn't in standby/suspend mode.
    • The indicator LEDs along the edges should be unlit. The laptop should be silent.
    • If you accidentally turn on the laptop during repair, hold the power button down for 10 seconds to shut it down.
    • Make sure your Framework Screwdriver has the T5 Torx bit (labeled as T-5) facing outwards. If it's not, pull the bit out and flip it.
  2. Framework Laptop 12 Fan Replacement, Set your laptop down: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Set your Framework Laptop face-down on a clean work surface.
  3. Framework Laptop 12 Fan Replacement, Loosen the bottom screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Fan Replacement, Loosen the bottom screws: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your Framework Screwdriver to fully loosen the eight captive T5 Torx screws on the bottom of your laptop.
    • Most screws in your Framework Laptop (including these) are captive—they're designed to stay in place after you loosen them.
    • Your laptop comes with a spare set of screws in the frame above the battery. Be careful—the replacement screws aren't captive.
  4. Framework Laptop 12 Fan Replacement, Flip your laptop over: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip your laptop over so it's face-up on your work surface.
  5. Framework Laptop 12 Fan Replacement, Open your laptop: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Fan Replacement, Open your laptop: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the laptop lid so that both the screen and the base lie flat on your work surface.
  6. Framework Laptop 12 Fan Replacement, Remove the Input Cover: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Fan Replacement, Remove the Input Cover: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Fan Replacement, Remove the Input Cover: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to grip the Input Cover in the hinge cutouts.
    • Lift upwards to swing the Input Cover up from the base of the laptop.
    • There are magnets holding the Input Cover down, so you'll feel some resistance. If it feels like a lot of force is required, check that you've fully loosened all the screws on the bottom of your laptop.
    • Remove the Input Cover.
  7. Framework Laptop 12 Fan Replacement, Loosen the battery screws: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Framework Screwdriver to loosen the six captive T5 Torx screws securing the battery.
  8. Framework Laptop 12 Fan Replacement, Disconnect the battery: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Fan Replacement, Disconnect the battery: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the orange battery tab with your fingers and lift straight up to disconnect the battery.
    • The battery connector can be tight, requiring some force. If it feels like part of the battery won't come up, check that the battery screws are fully loosened.
  9. Framework Laptop 12 Fan Replacement, Remove the battery: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Fan Replacement, Remove the battery: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift and remove the battery from the laptop.
  10. Framework Laptop 12 Fan Replacement, Disconnect the fan connector: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Fan Replacement, Disconnect the fan connector: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Fan Replacement, Disconnect the fan connector: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of your Framework Screwdriver to gently push on one of the fan connector's protruding edges, then the other, to loosen the connector out of its socket.
  11. Framework Laptop 12 Fan Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Fan Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers and your Framework Screwdriver to slide the fan connector out of its socket.
  12. Framework Laptop 12 Fan Replacement, Loosen the fan screws: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Framework Screwdriver to loosen the two captive T5 Torx screws securing the fan.
  13. Framework Laptop 12 Fan Replacement, Remove the fan: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Fan Replacement, Remove the fan: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift and remove the fan.
  14. Framework Laptop 12 Fan Replacement, Clean the fan: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Fan Replacement, Clean the fan: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If your fan's dirty, this is a great opportunity to clean it! A clean fan will help your laptop stay cooler.
    • Use a soft bristled brush or a clean toothbrush to gently scrub the fan blades and exhaust fins.
    • Use a dust blower to blow away the dust from the fan.
  15. Framework Laptop 12 Fan Replacement, Disassembly complete: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
  16. Framework Laptop 12 Fan Replacement, Install the fan: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lay the fan in the laptop.
  17. Framework Laptop 12 Fan Replacement, Tighten the fan screws: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Framework Screwdriver to tighten the two captive T5 Torx screws to secure the fan.
  18. Framework Laptop 12 Fan Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Fan Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to gently push the fan connector back into its socket.
    • Don't push too hard, or you may break the socket. If you're having trouble, wiggle the connector slightly to help it slide into the socket.
  19. Framework Laptop 12 Fan Replacement, Install the battery: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lay the battery in its recess in the laptop.
  20. Framework Laptop 12 Fan Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Fan Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your finger to push the battery down near its connector to reconnect it.
  21. Framework Laptop 12 Fan Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Framework Screwdriver to tighten the six captive T5 Torx screws to secure the battery.
    • Tighten the screws until they're snug. Don't over-tighten them, or you may strip the screws.
  22. Framework Laptop 12 Fan Replacement, Install the Input Cover: crwdns2935265:022crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Fan Replacement, Install the Input Cover: crwdns2935265:022crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Fan Replacement, Install the Input Cover: crwdns2935265:022crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Angle the bottom edge of the Input Cover towards the base of the laptop.
    • Align and insert the bottom edge of the Input Cover into the base of the laptop.
    • Make sure the slots along the bottom edge of the Input Cover slide into the tabs in the base.
    • Lower the Input Cover's top edge onto the laptop until the magnets snap it in place.
    • Make sure the Input Cover sits neatly within the laptop frame and no corners are popping up.
  23. Framework Laptop 12 Fan Replacement, Close and flip your laptop: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Fan Replacement, Close and flip your laptop: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Close the laptop lid.
    • Flip your laptop face-down on a clean work surface.
  24. Framework Laptop 12 Fan Replacement, Tighten the bottom screws: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Fan Replacement, Tighten the bottom screws: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your Framework Screwdriver to tighten the eight captive T5 Torx screws on the bottom of your laptop.
You finished fixing your Framework Laptop!
If you need help, contact Framework support.
Arthur Shi
crwdns2935283:001/03/18crwdne2935283:0
298,023 crwdns2915208:0crwdne2915208:0
crwdns2935297:0682crwdne2935297:0
Guide Team crwdns2935289:0Guide Teamcrwdne2935289:0
Staff
crwdns2931471:09crwdne2931471:0
crwdns2935297:013,440crwdne2935297:0
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 96
crwdns2942667:0crwdne2942667:0 154
