Fossil Q Marshal Gen 2 Screen Replacement
crwdns2942287:0crwdne2942287:0This repair guide will show you how to replace the screen on a Fossil Q Marshal Gen 2 smartwatch. Be careful not to damage the wiring or the metal connectors on your smartwatch.
crwdns2944105:0crwdne2944105:0
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Squeeze retaining pins together to release chain from watch body. This can be done by hand or with tweezers.
Remove chain from opposing side of watch body.
Use tweezers to grip the notches on the back cover, then unscrew the back cover (counter-clockwise) from the watch housing.
Utilize tweezers or a spudger or your fingers to pull the black wire connector from the motherboard.
Utilize a spudger to pull the orange connector off of the motherboard.
Utilize tweezers to pull the white battery connector from the motherboard.
The internal electronics can now be pulled out of the watch as one unit leaving the screen remaining in the watch housing.
Taking the flat end of the spudger, pry it up.
The screen can now be removed out of the front-side of the watch.
Where can I buy the replacement screen from?
Where can I find you so that my screen can be replaced? I am in Nairobi Kenya
Boas tardes. Onde poderei encontrar um ecrã. Parti o meu e não encontro em lado nenhum será possível ajudar obrigado
crwdns2935229:012crwdne2935229:0
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0crwdns2947412:017crwdne2947412:0
Where can i find a replacement screen for the founder q 2.0 version?
Where can I buy replacement screen for gen 1
Is the screen glued to the bezel of the watch?
Hello,
Do you have spare parts for the Fossil Q Marshal gen 2 watch?
Where can I find a replacement screen for this devise?, I’ve done a little searching but I’m struggling to find someone who sells the replacement parts.
Where can I get a replacement for this screen?
Has podido encontrar el repuesto?
Hola, donde consigo el repuesto de la pantalla? Gracias
Pablo Fernando Rios Corredor - crwdns2934203:0crwdne2934203:0
Guys, Scroll down to “store” then choose your country then do your search.
Need replacement glass is cracked where can I find one
I need his lcd plz help me where can i buy
Anyone find replacement screens?
I need the screen
Where can I get a screen replacement, battery and Home button of Fossil Q MARSHALL watch
the screen of smart watch is only half the pictures are visible the other side is blackout but it is touchable
where can i buy or find screen for the smart watch fossil
I’ve searched every single shop all around the world, but didn’t found any Fossil Smartwatch Display. Where can I get it from? I need on efor my Fossil Q Explorist HR (Gen 4) and I suggest it’s the same Display as the one for the Q Marshall.
ડીસપ્લેબદવીછે
