Fosera Scandle 200 Solar Panel Replacement
  1. Fosera Scandle 200 Solar Panel Replacement, Solar Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the case by pulling the back tab toward you in a downward motion.
  2. Fosera Scandle 200 Solar Panel Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the two Phillips #2 5mm screws that hold the power cord in place.
  3. Fosera Scandle 200 Solar Panel Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the flat-end of the spudger to pry off the clamp which holds the cord down.
  4. Fosera Scandle 200 Solar Panel Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the soldering iron to melt down the solder on each terminal by holding the tip of the iron against the solder until it becomes liquefied.
  5. Fosera Scandle 200 Solar Panel Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull the leads free from the terminals. If they do not easily separate from the terminals, repeat Step 4.
    • Now any solar panel of appropriate Voltage rating can be used to charge the device by soldering the wire leads to the new panel. Try to find a panel with similar specifications to avoid overloading the battery.
Vincent C
crwdns2935283:009/23/14crwdne2935283:0
134 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 12-5, Blackwell Fall 2014 crwdns2935289:0USF Tampa, Team 12-5, Blackwell Fall 2014crwdne2935289:0
USFT-BLACKWELL-F14S12G5
crwdns2935297:011crwdne2935297:0
In order to use solar energy efficiently, we need to learn how to store solar energy. Unfortunately, we can only store a small fraction of the sun's energy.
niks adonis - crwdns2934203:0crwdne2934203:0
More information here.
niks adonis -
crwdns2942667:0crwdne2942667:0 604
