Ford Focus Radio Suppression Capacitor Replacement
  1. Ford Focus Radio Suppression Capacitor Replacement, Radio Suppression Capacitor: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ford Focus Radio Suppression Capacitor Replacement, Radio Suppression Capacitor: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ford Focus Radio Suppression Capacitor Replacement, Radio Suppression Capacitor: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pop the hood of the 2007 Ford Focus using the pull lever under the steering wheel.
    • Secure the hood with the hood prop on the left side of the engine.
  2. Ford Focus Radio Suppression Capacitor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ford Focus Radio Suppression Capacitor Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ford Focus Radio Suppression Capacitor Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To disconnect the battery follow steps 2-4.
    • Loosen the bracket with the wrench.
    • Remove the top cover.
  3. Ford Focus Radio Suppression Capacitor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ford Focus Radio Suppression Capacitor Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ford Focus Radio Suppression Capacitor Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • You should wear protective gloves and goggles/glasses when working with the battery.
    • Remove the negative cable (usually black in color and labeled - or "Negative" ) by turning the nut clockwise with the wrench.
    • Set the ground cables away from the battery to avoid electrocution.
  4. Ford Focus Radio Suppression Capacitor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ford Focus Radio Suppression Capacitor Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the positive cable (usually red in color and labeled with + or "Positive")by turning the nut clockwise with the wrench.
  5. Ford Focus Radio Suppression Capacitor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ford Focus Radio Suppression Capacitor Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the first anchor bolt that attaches the metal clip to the engine mount.
    • Replace the anchor bolt if corroded.
  6. Ford Focus Radio Suppression Capacitor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ford Focus Radio Suppression Capacitor Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the second anchor bolt that secures the metal mount.
  7. Ford Focus Radio Suppression Capacitor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ford Focus Radio Suppression Capacitor Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ford Focus Radio Suppression Capacitor Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Detach the wiring harness by holding down the tab on the top of the clip.
    • Pull apart.
  8. Ford Focus Radio Suppression Capacitor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Obtain the new capacitor and reattach it by reversing the same steps you followed to disconnect the old capacitor.
Install the new capacitor by following the steps above in reverse order.
Amin Sadessi
crwdns2935283:004/28/17crwdne2935283:0
194 crwdns2915208:0crwdne2915208:0
UC Davis, Team S1-G6, Coad Spring 2017 crwdns2935289:0UC Davis, Team S1-G6, Coad Spring 2017crwdne2935289:0
UCD-COAD-S17S1G6
Do I have to have this part as it keeps arcing on the body or frame of my car and shorten out my ignition fuse. So do I have to have this part because I noticed when I unplugged it my car cranked up and ran because I forgot to plug it back in. How long can I run without it and what damage does it do? Because I know it has to do with the radio interference with within the steering wheel or something like that and I have no radio so I don't know if that matters
Lisa Jackson - crwdns2934203:0crwdne2934203:0
The wires on mine broke off completely and without the capacitor my focus won't even crank over at all..
miles goddard - crwdns2934203:0crwdne2934203:0
Just found out that one of the wires on mine is snapped off. Our car has been having the dash going in and out for a few weeks now. I was told to check the ground connection, but didn't look over on that side until today. This part is the only part that looks broken with wires.
zappy4 - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 126
crwdns2942667:0crwdne2942667:0 20,801
