If you have a foldable shopping cart whose front wheels no longer work, then this guide will help you replace your wheels so you don't have to worry about buying another cart. This guide is necessary for individuals who rely on a foldable shopping cart as a practical and economical means of transportation. A shopping cart with bad wheels can cause it to collapse on itself and cause an accident in the middle of the street, which is why it's essential to change the wheels to avoid accidents and remove the idea of getting rid of the shopping cart simply because the wheels don't work.
For the replacement, you can get an extra pair of wheels or new ones. The wheels must be a similar size to the ones you are trying to replace, and the axle must be clear enough to pass through. If anything blocks one end, it won't work. However, it's okay if one end is a little narrower from one end but still clear, as it would allow it to be inserted. Before you start, make sure to clear the area you are working on.
Set up the shopping cart by laying it down with the back wheels on the floor.
Remove a single wheel by pinching the locking mechanism and slide off the wheel with your hands.
Repeat the process in step 3 to remove the second wheel.
This is how it should look with the wheels completely off.
Looking to get front wheels been having a hard time finding do they have a name for the front wheels
Prepare the new wheels by ensuring the axle is clear from both sides.
Ensure the axle is closing in a bit on one end, as this will help lock it in.
Insert the remaining wheel by repeating step 7.
Ensure the wheels are securely locked, and check if you can move the car freely.
Can you put other wheels on the cart that doesn't swirl
Replace the swirling wheels with the one wheel on my cart can I do it
Where can I get these type of front swivel wheels to purchase?
Great tip! Thank you. How do you remove the back wheels? Thank you.
Where can I get the smaller 3 wheels do they have a one wheel that can go on instead
