Flipper Zero NFC antenna Replacement
    • Go to Main Menu > Settings > Power.
    • Select Power OFF.
    • Alternatively, you can press and hold the Back-button for around 10 seconds.
    • Confirm by pressing the Right-button.
  1. Flipper Zero NFC antenna Replacement, Remove the microSD card: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Eject the microSD card by pressing it with your fingernail.
  2. Flipper Zero NFC antenna Replacement, Remove the screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Phillips #0 Screwdriver
    $5.49
    • Use a PH0 screwdriver to unscrew the four long screws holding the back cover.
    • Be careful, the screws are quite easy to strip.
  3. Flipper Zero NFC antenna Replacement, Open the back cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Flipper Zero NFC antenna Replacement, Open the back cover: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Flipper Zero NFC antenna Replacement, Open the back cover: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press the middle of the top cover on both sides, one by one, to release the latches that hold the back cover in place.
    • Once the latches are released, you can remove the bottom cover.
  4. Flipper Zero NFC antenna Replacement, Remove the antenna: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Flipper Zero NFC antenna Replacement, Remove the antenna: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Flipper Zero NFC antenna Replacement, Remove the antenna: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    iFixit Opening Picks (Set of 6)
    • The board with the NFC antenna is glued to the bottom cover with adhesive tape.
    • To remove the board, gently pry one of the edges of the board with a plastic pick to peel off the adhesive tape.
    • Gently pull out the rest of the board by hand.
To reassemble your device, follow these instructions in reverse order and apply new adhesive where needed.
Sebastian
crwdns2935283:008/19/18crwdne2935283:0
28,783 crwdns2915208:0crwdne2915208:0
crwdns2935297:071crwdne2935297:0
German Translators crwdns2935289:0German Translatorscrwdne2935289:0
Community
crwdns2931471:037crwdne2931471:0
crwdns2935297:01,223crwdne2935297:0
Bonjour, où trouve-t'on cette antenne de rechange svp ?
christelle Poulailleau - crwdns2934203:0crwdne2934203:0
Il n'y a actuellement aucune antenne de remplacement officielle en vente, mais vous pourriez acheter un Flipper Zero défectueux sur eBay et l'utiliser comme donneur, ou tenter votre chance sur AliExpress.
Sebastian -
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 77
crwdns2942667:0crwdne2942667:0 2,808
