Flipper Zero Display Replacement
    • Go to Main Menu > Settings > Power.
    • Select Power OFF.
    • Alternatively, you can press and hold the Back-button for around 10 seconds.
    • Confirm by pressing the Right-button.
  1. Flipper Zero Display Replacement, Remove the microSD card: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Eject the microSD card by pressing it with your fingernail.
  2. Flipper Zero Display Replacement, Remove the screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Phillips #0 Screwdriver
    $5.49
    • Use a PH0 screwdriver to unscrew the four long screws holding the back cover.
    • Be careful, the screws are quite easy to strip.
  3. Flipper Zero Display Replacement, Open the back cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Flipper Zero Display Replacement, Open the back cover: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Flipper Zero Display Replacement, Open the back cover: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press the middle of the top cover on both sides, one by one, to release the latches that hold the back cover in place.
    • Once the latches are released, you can remove the bottom cover.
  4. Flipper Zero Display Replacement, Seperate the chassis from the top cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Flipper Zero Display Replacement, Seperate the chassis from the top cover: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    $5.49
    • Use a PH0 screwdriver to unscrew the two short screws that are holding the chassis and top cover together.
    • Once the screws are removed, separate the chassis from the top cover.
  5. Flipper Zero Display Replacement, Disconnect the battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Spudger
    $3.99
    • Disconnect the battery by carefully prying the connector with a Spudger and pulling it out.
  6. Flipper Zero Display Replacement, Disconnect the ribbon cable: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    iFixit Opening Picks (Set of 6)
    • Disconnect the large ribbon cable from the board. Use a plastic pick to lift the latch up to open the lock and carefully pull it out of the connector.
  7. Flipper Zero Display Replacement, Release the battery chassis: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Flipper Zero Display Replacement, Release the battery chassis: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To release the battery chassis, lightly rock it back and forth while pulling the two parts apart.
    • Be sure to apply gentle and consistent pressure to avoid damaging the device.
  8. Flipper Zero Display Replacement, Unscrew the the button chassis: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    $5.49
    • Unscrew the two short screws holding the button chassis using a PH0 screwdriver.
  9. Flipper Zero Display Replacement, Seperate the button chassis: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Flipper Zero Display Replacement, Seperate the button chassis: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Flipper Zero Display Replacement, Seperate the button chassis: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To seperate the button chassis and the board, press the latch on the side shown below and pull the chassis away from the board.
  10. Flipper Zero Display Replacement, Disconnect the screen: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Flipper Zero Display Replacement, Disconnect the screen: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the screen ribbon cable from the board. Use a plastic pick to lift the latch up to open the lock and carefully pull it out of the connector.
  11. Flipper Zero Display Replacement, Desolder the screen: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the screen you need to desolder two contacts.
    • See this guide on how to solder and desolder connections.
crwdns2935229:015crwdne2935229:0
Sebastian
crwdns2935283:008/19/18crwdne2935283:0
31,160 crwdns2915208:0crwdne2915208:0
crwdns2935297:071crwdne2935297:0
crwdns2947412:013crwdne2947412:0
Everything worked fine following this guide. Thank you for the help. In my case was just the glass that was broken, so at the end, i didnt needed to desolder. Just removed the glass with the Plastic pick and worked perfectly. Thank you again for the help.
arthureldo - crwdns2934203:0crwdne2934203:0
Where did you find a replacement glass?
Ben Durrant -
The company behind FZ is not selling screen replacement (they promise they will do it in the future) but for now... So i don't what to think about this guide
Gusbill - crwdns2934203:0crwdne2934203:0
Where can you get an LCD replacement (backlit)?
David Williams - crwdns2934203:0crwdne2934203:0
Checked with Flipper Zero Support and they said there's no replacement screens available. Found one on AliExpress and ordered it so I'll post here in about a month once the display has arrived and I have time to try the replacement, then report back and link the part if successful.
Cody Ouellette - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 104
crwdns2936753:030crwdne2936753:0 505
crwdns2942667:0crwdne2942667:0 23,698
