Flipper Zero Battery Replacement
    • Go to Main Menu > Settings > Power.
    • Select Power OFF.
    • Alternatively, you can press and hold the Back-button for around 10 seconds.
    • Confirm by pressing the Right-button.
  1. Flipper Zero Battery Replacement, Remove the microSD card: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Eject the microSD card by pressing it with your fingernail.
  2. Flipper Zero Battery Replacement, Remove the screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Phillips #0 Screwdriver
    $5.49
    • Use a PH0 screwdriver to unscrew the four long screws holding the back cover.
    • Be careful, the screws are quite easy to strip.
  3. Flipper Zero Battery Replacement, Open the back cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Flipper Zero Battery Replacement, Open the back cover: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Flipper Zero Battery Replacement, Open the back cover: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press the middle of the top cover on both sides, one by one, to release the latches that hold the back cover in place.
    • Once the latches are released, you can remove the bottom cover.
  4. Flipper Zero Battery Replacement, Seperate the chassis from the top cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Flipper Zero Battery Replacement, Seperate the chassis from the top cover: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    $5.49
    • Use a PH0 screwdriver to unscrew the two short screws that are holding the chassis and top cover together.
    • Once the screws are removed, separate the chassis from the top cover.
  5. Flipper Zero Battery Replacement, Disconnect the battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Spudger
    $3.99
    • Disconnect the battery by carefully prying the connector with a Spudger and pulling it out.
  6. Flipper Zero Battery Replacement, Disconnect the ribbon cable: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    iFixit Opening Picks (Set of 6)
    • Disconnect the large ribbon cable from the board. Use a plastic pick to lift the latch up to open the lock and carefully pull it out of the connector.
  7. Flipper Zero Battery Replacement, Release the battery chassis: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Flipper Zero Battery Replacement, Release the battery chassis: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To release the battery chassis, lightly rock it back and forth while pulling the two parts apart.
    • Be sure to apply gentle and consistent pressure to avoid damaging the device.
  8. Flipper Zero Battery Replacement, Remove the lace mount: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    $5.49
    • To remove the lace mount, use a PH0 screwdriver to unscrew the short screw that is securing it in place.
  9. Flipper Zero Battery Replacement, Remove the battery: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Flipper Zero Battery Replacement, Remove the battery: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Flipper Zero Battery Replacement, Remove the battery: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The battery is attached to the chassis with double-sided tape. To remove it, use a plastic pick to gently peel the battery off the chassis.
    • Caution: Don't jab the battery with any sharp tools. A punctured battery may leak dangerous chemicals or catch fire.
To reassemble your device, follow these instructions in reverse order and apply new adhesive where needed.
Sebastian
crwdns2935283:008/19/18crwdne2935283:0
29.490 crwdns2915208:0crwdne2915208:0
crwdns2935297:071crwdne2935297:0
where can I buy the replacement batterie ?
Piot Gabriel - crwdns2934203:0crwdne2934203:0
where can I get the replacement battery?
collin - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 59
crwdns2936753:030crwdne2936753:0 270
crwdns2942667:0crwdne2942667:0 9,295
