Fixing a Refrigerator Door Seal
  1. Fixing a Refrigerator Door Seal, Fixing a Refrigerator Door Seal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fixing a Refrigerator Door Seal, Fixing a Refrigerator Door Seal: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fixing a Refrigerator Door Seal, Fixing a Refrigerator Door Seal: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab a Phillips Head Screw Driver
    • Lift up the door seal and locate the screws underneath that hold the seal in place. Loosen the screws to where they are pretty loose, but not out of their hole.
    • Note To save energy, you can turn off your refrigerator before proceeding to steps 2-6.
  2. Fixing a Refrigerator Door Seal: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fixing a Refrigerator Door Seal: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fixing a Refrigerator Door Seal: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After all the screws are loose, the door seal should slide off fairly easy. Slowly remove the door seal with your hands by peeling it off the seal's shell.
  3. Fixing a Refrigerator Door Seal: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fixing a Refrigerator Door Seal: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fixing a Refrigerator Door Seal: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Thoroughly wash the door seal in Soap and Water
    • Using a paper towel (or regular towel), dry the seal.
    • Note If your seal has cracks in it, you will need to replace it. If this is the case, skip this step.
  4. Fixing a Refrigerator Door Seal: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fixing a Refrigerator Door Seal: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • On the side that connects to the refrigerator unit, apply a thin layer of silicon grease. This will improve functionality as well as prevent the seal from cracking in the future.
  5. Fixing a Refrigerator Door Seal: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fixing a Refrigerator Door Seal: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fixing a Refrigerator Door Seal: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To reattach the seal,feed the back of the seal behind the white frame.
    • It is easiest to do this by starting at any corner and completing one side at a time.
  6. Fixing a Refrigerator Door Seal: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fixing a Refrigerator Door Seal: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fixing a Refrigerator Door Seal: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Make sure the white shell is holding the seal in place on all sides.
    • Tighten all of the screws back in place.
Your refrigerator should now stay shut properly, and the seal should be tightly secured in place. To assure proper functionality, check every once in awhile to make sure the seal is firmly in place.
crwdns2935229:065crwdne2935229:0
Curtis Rosol
crwdns2935283:004/09/15crwdne2935283:0
2.045 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 30-5, Green Spring 2015 crwdns2935289:0Cal Poly, Team 30-5, Green Spring 2015crwdne2935289:0
CPSU-GREEN-S15S30G5
crwdns2935297:032crwdne2935297:0
crwdns2947412:011crwdne2947412:0
Love that you show how to fix on a mini fridge! #CollegeLife Thanks for this :)
tcarle1191 - crwdns2934203:0crwdne2934203:0
How can I fix the seals on chest fridge.
Ramon Espinoza - crwdns2934203:0crwdne2934203:0
Thank you for such a great article with the pictures, it is really helpful! I have just looked at my fridge door, lookes like i know how to detach the seal, but… i am afraid i won´t be able to put it back again…)))
AngiGi - crwdns2934203:0crwdne2934203:0
buy a new fridge - i wood- support american union workers
dkp50 - crwdns2934203:0crwdne2934203:0
How much should the GE repairman charge for this repair? My mother-in-law was told it’ll cost her between $250-$275. I think that’s too much due to the cost of the seal. Does the labor cost account for the extra $200?
Raymond Frazier - crwdns2934203:0crwdne2934203:0
CLICK on the link here to help us engineering students to solve Fridge door problems!! https://docs.google.com/forms/d/e/1FAIpQ...
Brock Erekson - crwdns2934203:0crwdne2934203:0
DON'T PUT VASELINE. I've ruined 2 fridges with this, now they're constantly running. You'll need silicon grease. This article is right. If it ain't broke, don't fix it, and &&^& the Vaseline guys
Mait Oliver Hellat - crwdns2934203:0crwdne2934203:0
The seal was indeed damaged, but the door is unbalanced. Next repair for my 30 year old fridge.
Thanks for the great guidance.
Pamela Johnson - crwdns2934203:0crwdne2934203:0
Buy used support the little guy who refurbish
Leslie Newman - crwdns2934203:0crwdne2934203:0
Thanku so much. It was really helpful. Got my problem fixed by ur advice.
ISRAR UL HAQ - crwdns2934203:0crwdne2934203:0
How to fix a fridge or freezer seal: The easy way!
Use Duct tape to hold the door closed while you push (gently crushing the door seal) the door closed as hard as you can easily do. Leave the duct tape on for about 24 hours.
In most cases this will cause the door seal to re-level itself and seal better for a long time to come.
Generally, if a dollar bill placed between the door and the fridge comes out EASILY it means that that spot is not sealing well.
Glenn N. Davis - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 28
crwdns2936753:07crwdne2936753:0 159
crwdns2936753:030crwdne2936753:0 769
crwdns2942667:0crwdne2942667:0 325,710
