The model of this particular faucet is unknown although I believe it is a Kingston brass given the handle design. If you need to find out the model of your faucet you can check the handles for the brand tag/logo or the stem canister of the handle. To check the stem canister you may have to completely remove the faucet base. A quick google search will show you how to do this as it is not covered in this guide. This guide shows the user how to fix a leaky faucet neck by replacing the O-ring found between the faucet neck and faucet base. This O-ring acts as a seal to prevent leakage while the faucet is running. The O-ring can be found at your home improvement store and is a fairly common item. An important note worth mentioning is that by taking your faucet neck into one of these home improvement stores you will receive help on what size O-ring you will need.
Here is an article to more insight on finding your faucet model:
Rotate both the hot and cold water valves underneath the sink in order to turn them off.
Test that the water is turned off by turning the faucet on for both cold and hot water and checking if any water runs. If there is still running water, you either turned the wrong valve(s), or you need to turn them the other direction.
Place the claw of an adjustable wrench around the threads on the neck of the sink and twist the wrench clockwise to unscrew the two parts.
After taking the neck off check the O-ring located on the bottom of the neck.
Pull the black o-ring off of the end of the faucet.
To put the new O-ring on, slide one end of the O-ring on with both thumbs
Use the pressure with your thumbs to gently slide it on completely.
Now that you have the O-ring completely on, you are ready to reconnect the neck back to the base of the faucet.
Screw the neck back on the base of the faucet and tighten it with your bare hands.
Remember to turn your water back on by turning the water supply valves under the sink!
I have always faced a leaky pipe problem and get worried that how can I replace it or should I call an emergency plumber? But this guide is really nice and contains complete knowledge about how to repair the leaky faucet from its neck. I will try to repair my leaky faucet through your given steps. Thanks for sharing this guide.
