Fix iPhone X Unable to Activate By Jumper Wires
crwdns2936621:0crwdne2936621:0
  1. Fix iPhone X Unable to Activate By Jumper Wires, Jumper Wires: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fix iPhone X Unable to Activate By Jumper Wires, Jumper Wires: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The iPhone X has been dropped and can’t work normally. After restoring, the phone can’t be activated. Next, we try to activate the phone with 3uTools.
    • Connect the phone to the computer and open 3uTools. Click Activate Now and Start.
    • The activation normally takes several minutes. After about 20 minutes, the phone is stuck in the activation interface. The phone is still unable to be activated.
  2. Fix iPhone X Unable to Activate By Jumper Wires: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fix iPhone X Unable to Activate By Jumper Wires: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Next, we need to separate the motherboard for further check.
    • Put the motherboard on the 165 °C Heating Platform to heat. When the temperature reaches 165 °C, remove the logic board and signal board with tweezers.
  3. Fix iPhone X Unable to Activate By Jumper Wires: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fix iPhone X Unable to Activate By Jumper Wires: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fix iPhone X Unable to Activate By Jumper Wires: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Clear thermal grease with a Sculpture Knife.
    • After separation, it is found that there are many missing pads. Then we restore useful pads from missing pads with jumper wires.
    • Attach the logic board to the holder and remove tin on the bonding pad with Soldering Iron at 365 °C and Solder Wick.
  4. Fix iPhone X Unable to Activate By Jumper Wires: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fix iPhone X Unable to Activate By Jumper Wires: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fix iPhone X Unable to Activate By Jumper Wires: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply some Solder Paste to the missing pads and apply tin with Hot Air Gun at 340 °C. Clean the bonding pad with PCB Cleaner and apply some Paste Flux.
    • Solder 0.02 mm copper wires to the bonding pad with Soldering Iron. Please be noted that copper wires must be soldered firmly.
    • Clean with PCB Cleaner again and curl the copper wires to make pads with Tweezers and Sculpture Knife.
  5. Fix iPhone X Unable to Activate By Jumper Wires: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fix iPhone X Unable to Activate By Jumper Wires: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fix iPhone X Unable to Activate By Jumper Wires: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply Solder Mask to the bonding pad to fix the copper wires and solidify the solder mask with UV Lamp for 5 minutes.
    • Scrape away excess solder mask with Sculpture Knife to show the copper wires.
    • Next, remove tin on the bonding pad with Soldering Iron at 365 °C and Solder Wick. Clean the bonding pad with PCB Cleaner.
  6. Fix iPhone X Unable to Activate By Jumper Wires: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fix iPhone X Unable to Activate By Jumper Wires: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fix iPhone X Unable to Activate By Jumper Wires: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Attach the signal board to the Reballing Platform and put the reballing stencil in position.
    • To prevent solder paste from flowing into the motherboard, insert a metal plate.
    • Apply evenly a layer of low-temperature Solder Paste.
  7. Fix iPhone X Unable to Activate By Jumper Wires: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fix iPhone X Unable to Activate By Jumper Wires: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After the solder balls are formed, turn the power off and cool the signal board. Apply some Paste Flux and align the logic board with the signal board.
    • Keep heating for 1 minute when the temperature reaches 165 °C. Turn the power off and cool the motherboard.
  8. Fix iPhone X Unable to Activate By Jumper Wires: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fix iPhone X Unable to Activate By Jumper Wires: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Then we install the motherboard to the phone. Open 3uTools to activate the phone. The phone is successfully activated.
    • Test other functions and other functions work well.
REWA
crwdns2935283:011/24/20crwdne2935283:0
18 090 crwdns2915208:0crwdne2915208:0
crwdns2935297:055crwdne2935297:0
crwdns2936753:030crwdne2936753:0 35
crwdns2942667:0crwdne2942667:0 1,606
