This is a quick and easy guide to replace the wristband of a Fitbit Alta. No tools are required in the process.
To release a latch, press down on the flat metal button holding the band to the Fitbit Alta. Pull up on the latch to release the band from the body.
Slide the band up to release it from the Fitbit Alta tracker. Then, repeat on the other side to remove the band.
Donde consigo cargador o como lo cargo lo extravie el cargador
Turn over the Fitbit Alta so the bands are facing upward.
Press the latches inward and remove each band by lifting upward.
To reassemble your device, follow these instructions in reverse order. When you hear a click , the wristband is secure.
crwdns2935229:013crwdne2935229:0
Excellent! Thanks so much!
My band broke off and the tab used for removal broke and I cannot get my remnant of my band off. What are the steps for removing the band if the tab is broken?
