Fender Starcaster Tuning Heads Replacement
Christopher Hartigan
crwdns2944107:0crwdnd2944107:0Christopher Hartigancrwdnd2944107:0crwdnd2944107:0crwdnd2944107:04crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Kho 4, 2019crwdne2944111:0
15 - 30 crwdns2931279:0crwdne2931279:0
crwdns2937801:0crwdne2937801:0
crwdns2942287:0crwdne2942287:0
If the tuners have broken, become excessively lose, or seized, they will require replacement.
crwdns2944105:0crwdne2944105:0
  1. Fender Starcaster Tuning Heads Replacement, Loosen the Strings: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fender Starcaster Tuning Heads Replacement, Loosen the Strings: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fender Starcaster Tuning Heads Replacement, Loosen the Strings: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Start by loosening the strings. This is done by turning the tuning knob until the string has lost tension.
    • Repeat this for all six strings on the guitar.
  2. Fender Starcaster Tuning Heads Replacement, Remove the Strings from the Tuning Pegs: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fender Starcaster Tuning Heads Replacement, Remove the Strings from the Tuning Pegs: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Be mindful of the string ends. They may be sharp and could puncture your skin.
    • It may be necessary to use pliers to remove string ends from the tuning peg.
  3. Fender Starcaster Tuning Heads Replacement, Remove the Strings from the Bridge: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fender Starcaster Tuning Heads Replacement, Remove the Strings from the Bridge: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fender Starcaster Tuning Heads Replacement, Remove the Strings from the Bridge: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After removing the strings from the tuning pegs, slide the strings through the bridge and out of the back of the guitar.
    • If the twists in the string ends are in the way, use wire cutters to snip them off. This will allow the heavier strings to pass through the bridge easier.
    When I cut 4-6 winding string, I have experience with the metal piece of the string entering my eyeball.
    It is recommended to wear goggles or cut with eyes closed.
    Takehiro - crwdns2934203:0crwdne2934203:0
  4. Fender Starcaster Tuning Heads Replacement, Tuning Heads: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fender Starcaster Tuning Heads Replacement, Tuning Heads: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a wrench, remove the nuts around each tuning head post.
  5. Fender Starcaster Tuning Heads Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fender Starcaster Tuning Heads Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fender Starcaster Tuning Heads Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Next, remove the threaded retainer sleeve from each post.
    • Don't forget the washer.
  6. Fender Starcaster Tuning Heads Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fender Starcaster Tuning Heads Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Next, remove the screws from the backside of each tuner.
  7. Fender Starcaster Tuning Heads Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fender Starcaster Tuning Heads Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Finally, remove the tuning machine assembly from the headstock.
crwdns2935283:009/10/14crwdne2935283:0
164 crwdns2915208:0crwdne2915208:0
Pasco Hernando, Team 5-3, Prince Fall 2014 crwdns2935289:0Pasco Hernando, Team 5-3, Prince Fall 2014crwdne2935289:0
PHSC-PRINCE-F14S5G3
crwdns2931471:09crwdne2931471:0
Does the 2013 Starcaster take a 10mm tuning peg?
Brian Seese - crwdns2934203:0crwdne2934203:0
This is only the removal. Nothing After step 7. What about the actual replacement? What did you replace them with? Did it involve any machining?
Richard Caruso - crwdns2934203:0crwdne2934203:0
This is only the removal. What about the actual replacement? What did you replace them with? Did it involve any machining?
crwdns2942667:0crwdne2942667:0 2,824
