Fender Starcaster String Replacement
  1. Fender Starcaster String Replacement, Loosen the Strings: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fender Starcaster String Replacement, Loosen the Strings: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fender Starcaster String Replacement, Loosen the Strings: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Start by loosening the strings. This is done by turning the tuning knob until the string has lost tension.
    • Repeat this for all six strings on the guitar.
  2. Fender Starcaster String Replacement, Remove the Strings from the Tuning Pegs: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fender Starcaster String Replacement, Remove the Strings from the Tuning Pegs: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Be mindful of the string ends. They may be sharp and could puncture your skin.
    • It may be necessary to use pliers to remove string ends from the tuning peg.
  3. Fender Starcaster String Replacement, Remove the Strings from the Bridge: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fender Starcaster String Replacement, Remove the Strings from the Bridge: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fender Starcaster String Replacement, Remove the Strings from the Bridge: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After removing the strings from the tuning pegs, slide the strings through the bridge and out of the back of the guitar.
    • If the twists in the string ends are in the way, use wire cutters to snip them off. This will allow the heavier strings to pass through the bridge easier.
    When I cut 4-6 winding string, I have experience with the metal piece of the string entering my eyeball.
    It is recommended to wear goggles or cut with eyes closed.
    Takehiro - crwdns2934203:0crwdne2934203:0
  4. Fender Starcaster String Replacement, String: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fender Starcaster String Replacement, String: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fender Starcaster String Replacement, String: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Take any one of the new strings and slide it through the appropriate bridge hole.
    • The replacement strings used on this guitar were "Regular Slinky" by Ernie Ball, which is a 10 gauge string set.
    • 6th String: E - 46 Gauge
    • 5th String: A - 36 Gauge
    • 4th String: D - 26 Gauge
    • 3rd String: G - 17 Gauge
    • 2nd String: B - 13 Gauge
    • 1st String: E - 10 Guage
  5. Fender Starcaster String Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fender Starcaster String Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fender Starcaster String Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lay the string parallel to the guitar's neck and directly over the appropriate tuning peg.
    • Measure a "three finger's length" (about 1.5") on the string passed the tuning peg.
    • Make a sharp bend in the string at where you measured 1.5" passed the tuning peg.
    • Turn the tuning peg until the string hole faces perpendicular to the guitar's neck.
    • Feed the bent string into the tuning peg until the bend meets the tuning post.
  6. Fender Starcaster String Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fender Starcaster String Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fender Starcaster String Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Make another sharp bend in the string on the outside of the tuning post.
    • Turn the tuning key counter clockwise while applying light pressure to the string on the inside of the post.
    • Wrapping the string around the post will help the string stay in-tune longer.
    • If the wraps of the string around the post start to roll over the top of the post, hold them down while still turning the post.
    • Continue turning the post until at least 2 full wraps of the string have been made around the post.
  7. Fender Starcaster String Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fender Starcaster String Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Snip the excess string off from the post with a wire cutter (leaving at least half an inch of string left).
  8. Fender Starcaster String Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fender Starcaster String Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fender Starcaster String Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Continue installing strings using the the same method described in the last few steps.
    • The last four strings (the D, G, B, and E strings), must be guided underneath the two "string trees" in the center of the headstock.
    • String Tree for the D and G strings
    • String Tree for the B and E strings
    • Tune the strings to your desired pitch and your guitar is ready to play!
Jasper Fleischhauer
crwdns2935283:010/20/14crwdne2935283:0
35,106 crwdns2915208:0crwdne2915208:0
crwdns2936753:07crwdne2936753:0 19
crwdns2942667:0crwdne2942667:0 6,233
