Fairphone Fairbuds USB-C Port Replacement
  1. Fairphone Fairbuds USB-C Port Replacement, Remove the earbuds: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fairphone Fairbuds USB-C Port Replacement, Remove the earbuds: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove your earbuds from the charging case.
  2. Fairphone Fairbuds USB-C Port Replacement, Remove the outer shell screw: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fairphone Fairbuds USB-C Port Replacement, Remove the outer shell screw: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip your charging case upside down.
    • Use a Phillips screwdriver to remove the 4.5 mm‑long screw securing the outer shell.
  3. Fairphone Fairbuds USB-C Port Replacement, Remove the battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fairphone Fairbuds USB-C Port Replacement, Remove the battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip up the bottom of the outer shell to expose the battery.
  4. Fairphone Fairbuds USB-C Port Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fairphone Fairbuds USB-C Port Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fairphone Fairbuds USB-C Port Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your finger to pry up the battery at its notch and remove it.
  5. Fairphone Fairbuds USB-C Port Replacement, Remove the charging core: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fairphone Fairbuds USB-C Port Replacement, Remove the charging core: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the charging core out of the outer shell and remove it.
  6. Fairphone Fairbuds USB-C Port Replacement, Remove the charging core screws: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fairphone Fairbuds USB-C Port Replacement, Remove the charging core screws: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the six 3.9 mm‑long screws securing the two halves of the charging core.
  7. Fairphone Fairbuds USB-C Port Replacement, Open the charging core: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fairphone Fairbuds USB-C Port Replacement, Open the charging core: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fairphone Fairbuds USB-C Port Replacement, Open the charging core: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip over the charging core and grip its top half, near the pairing button.
    • Lift the top half and swing it over the core, letting it rest on something sturdy.
    • Don't try to separate the two halves, as they're still attached by cables.
  8. Fairphone Fairbuds USB-C Port Replacement, Disconnect the mainboard: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fairphone Fairbuds USB-C Port Replacement, Disconnect the mainboard: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fairphone Fairbuds USB-C Port Replacement, Disconnect the mainboard: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to pull the left earbud charging cable out of its socket.
    • Don't grip the cable! Only pull on the cable's plastic head.
    • If you're having trouble gripping the cable's head, use the tip of a spudger to push it out of its socket.
  9. Fairphone Fairbuds USB-C Port Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fairphone Fairbuds USB-C Port Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fairphone Fairbuds USB-C Port Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Since the remaining connectors are next to each other, it can be difficult to grip them with your fingers. The following instructions use a spudger instead.
    • Use the tip of a spudger to push the right earbud cable head out of its socket to disconnect it.
    • Repeat for the USB-C port cable.
  10. Fairphone Fairbuds USB-C Port Replacement, Remove the mainboard screws: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fairphone Fairbuds USB-C Port Replacement, Remove the mainboard screws: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the two 3.9 mm‑long screws securing the mainboard.
  11. Fairphone Fairbuds USB-C Port Replacement, Remove the mainboard: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fairphone Fairbuds USB-C Port Replacement, Remove the mainboard: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fairphone Fairbuds USB-C Port Replacement, Remove the mainboard: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the mainboard off its posts in the charging core and remove it.
  12. Fairphone Fairbuds USB-C Port Replacement, Move the cable: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fairphone Fairbuds USB-C Port Replacement, Move the cable: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Move the USB-C port cable out of its groove next to the screw peg.
  13. Fairphone Fairbuds USB-C Port Replacement, Remove the USB-C port screws: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fairphone Fairbuds USB-C Port Replacement, Remove the USB-C port screws: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the two 3.9 mm‑long screws securing the USB-C port.
  14. Fairphone Fairbuds USB-C Port Replacement, Remove the USB-C port: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fairphone Fairbuds USB-C Port Replacement, Remove the USB-C port: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the USB-C port out of the charging core and remove it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Alex Diaz-Kokaisl
crwdns2935283:001/16/22crwdne2935283:0
174,265 crwdns2915208:0crwdne2915208:0
crwdns2935297:0798crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,911crwdne2935297:0
crwdns2936753:030crwdne2936753:0 72
crwdns2942667:0crwdne2942667:0 467
