Fairphone 5 USB-C Port Replacement
  1. Fairphone 5 USB-C Port Replacement, Prepare your phone for disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug all cables and power down your phone.
    • Press the power and volume up buttons at the same time to bring up the shutdown menu.
  2. Fairphone 5 USB-C Port Replacement, Pry up the back cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fairphone 5 USB-C Port Replacement, Pry up the back cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert your fingernail, or a pry tool like a spudger, under the notch at the bottom right of the back cover.
    • Pry up the back cover to release the bottom right corner clips.
  3. Fairphone 5 USB-C Port Replacement, Remove the back cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fairphone 5 USB-C Port Replacement, Remove the back cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fairphone 5 USB-C Port Replacement, Remove the back cover: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grip the bottom right corner of the back cover with one hand and brace the phone frame with the other.
    • Lift the back cover away from the phone to release the clips around its perimeter.
    • Remove the back cover.
    • During reassembly, align the back cover over the phone and press along the perimeter until all clips snap back into place.
  4. Fairphone 5 USB-C Port Replacement, Remove the battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fairphone 5 USB-C Port Replacement, Remove the battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fairphone 5 USB-C Port Replacement, Remove the battery: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingernail, or a pry tool like a spudger, to lift the battery by its tab along the bottom edge.
    • Remove the battery.
    • During reassembly, slide the top edge of the battery into its recess in the frame before pressing the battery into place.
  5. Fairphone 5 USB-C Port Replacement, Unfasten the loudspeaker: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fairphone 5 USB-C Port Replacement, Unfasten the loudspeaker: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips driver to remove the five 4.9 mm‑long screws securing the loudspeaker.
  6. Fairphone 5 USB-C Port Replacement, Remove the loudspeaker: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fairphone 5 USB-C Port Replacement, Remove the loudspeaker: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fairphone 5 USB-C Port Replacement, Remove the loudspeaker: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert your fingernail, or a pry tool like a spudger, under the notch at the bottom right corner of the loudspeaker.
    • Pry up the loudspeaker and pull it away from the bottom edge of the phone to separate it from the frame.
    • During reassembly, insert the bottom edge of the loudspeaker into its slot in the frame before pressing the loudspeaker into place.
  7. Fairphone 5 USB-C Port Replacement, Disconnect the charging port: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fairphone 5 USB-C Port Replacement, Disconnect the charging port: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tip of a spudger to pry up and disconnect the charging port press connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  8. Fairphone 5 USB-C Port Replacement, Remove the charging port: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fairphone 5 USB-C Port Replacement, Remove the charging port: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fairphone 5 USB-C Port Replacement, Remove the charging port: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the tip of a spudger under the metal plate at the head of the charging port.
    • Pry up to separate the charging port from its slot in the frame.
    • Remove the charging port.
    • During reassembly, insert the charging port at a downward angle into its slot before pressing it down flat.
Alex Diaz-Kokaisl
crwdns2935283:001/16/22crwdne2935283:0
174.382 crwdns2915208:0crwdne2915208:0
crwdns2935297:0798crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021.981crwdne2935297:0
crwdns2936753:07crwdne2936753:0 60
crwdns2936753:030crwdne2936753:0 268
crwdns2942667:0crwdne2942667:0 2,555
