Use this guide to replace the bottom module in your Fairphone 3.
Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom right of the back cover.
Pry the back cover up to start separating its plastic clips.
Slide around the bottom right corner of the back cover to loosen the lower plastic clips.
Lift the back cover to release the rest of the plastic clips and remove it.
Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
Lever the battery up until you can get a good grip.
Lift the battery out of its recess and remove it.
Remove the thirteen Phillips #00 screws (4 mm length).
vis M 1.4/4 mm
Attention : pour dévisser les deux vis du haut il est nécessaire d’avoir un tournevis assez fin, certains tournevis #0 seront trop gros et risquent de marquer les bords du trou, voire la caméra.
I used the knife edge (on my suiss knife) and it worked fine. Of course, be very very carful not to damage the screws. In one hole I had to "sacrifice" a little bit plastic since the hole was a little bit too narrow for the knife.
no opening pick supplied with phone or part, it seems, and no picture of where to insert it
Insert an opening pick between the midframe and the display module on the right edge of the phone.
Slide the opening pick down to the bottom right corner to pry open the plastic clamps of the display module.
Hello. I do not have an opening pick; one was not provided with the telephone or the camera module. How am I supposed to install the item if I have not been either provided with, or informed of the requirement for, a necessary tool? This makes it extremely difficult for a customer to make their own installations or repairs. Also, I do not have a spudger, and I had to look up what a spudger is. These are not everyday items found in most people’s toolboxes, so I feel that they should be provided, or a warning should be given when buying items (such as the camera module) which will require additional tools to install.
Hi, you are right, there should be a hint to buy those tools. Maybe you have a guitar pick or a very thin spatula or putty knife. It is better to not use metal, to not damage the frame, but if you have no other tool this may help.
Attention de bien insérer sur la rainure la plus à l'extérieur, vous allez sinon decoller le joint fixant l'écran à proprement parler au reste du module.
Si ça vous arrive, vous le saurez en voyant que la partie décollée est toujours reliée par une nappe à la partie inférieure de l'écran. Pas de panique, appliquez quelques points de colle par dessus le joint d'origine et recommencez la procédure, cette fois dans la bonne rainure (et la procédure devrait vous paraître beaucoup plus simple ;) )
Punaise, moi cette partie de mon écran se décolle toute seule. Juste un tout petit peu, par le haut. Vous me conseillez de le décoller plus pour pouvoir y mettre de la colle ?? Quelle colle serait le mieux ? (pas envie d’acheter un écran vu que le mien fonctionne très bien quand même)
Hello, I got frustrated when I didn’t find any opening pick. I’m not a guitarr player either ;-) , so I took a old credit card instead. It worked fine! I got a spudger when I bought the FP3.
Anyway, these tools are not common in most households, so they should be provided or at least they should be hinted that they are needed.
Hey, I cut the edge off a stiff plastic packaging and inserted it. It was itself too wobbly, but widened the gap enough so I could insert the edge of a credit card which worked just fine.
Ich hatte kein Plektrum habe es mit einer Chip-Karte probiert, das ging auch.
If you have somewhat long nails you don't need a special tool to begin opening it. Following the frame afterwards is easy with a plain screwdriver.
Slide the opening pick around the bottom right corner and use it to disengage the plastic clamps at the bottom of the display module.
Hallo
nachdem mein Handy ausversehen runtergefallen ist, war das Display dunkel; ein/aus half nichts, akku raus/rein auch nicht. Es gab Brumgeräusche wie beim Starten wenn ich Start gedrückt habe, das Display blieb dunkel. Ich konnte das Display mit etwas mühe(ungeübt) ausbauen und wieder einbauen. Danach ging es wieder; Danke euch hier für die Anleitung. So ein Plektrum habe ich leider nicht mehr, ich glaub es war eines dabei. Ich habe mir mit einem kleinen Plastiklöffel geholfen, der ist jetzt mein Star :-)
Sehr gut! Viel Spaß mit deinem Fairphone!
Slide the opening pick along the left side to pry the display module up.
Remove the display assembly.
The new display module comes with a white plastic cover held by 2 screws over the processor and the connectors. This needs to be taken off!
ATTENTION !l’écran neuf comprend un cache plastique qui tient avec 2 vis ! pour monter le nouvel écran il faut dévisser les vis et enlever le cache plastique
Die weiße Plastikabdeckung an dem neuen Modul muss vor dem Einbau noch gelöst werden (2 Schrauben).
Vielen Dank für die kleinschrittige Anleitung, dir mir als Reparaturmuffel geholfen hat, mein Handy wieder zu aktivieren. Hintergrund: nach einem Sturz war das Display total verpixelt. Durch aus- und Einbau des Displays wurden die durch den Sturz gelockerten Kontakte wieder neu verbunden und - siehe da - es funktioniert wieder alles wie am ersten Tag! Da bin ich froh, daß ich mich für ein fairphone entschieden habe.
Sehr gut! Weiter viel Spaß mit deinem Fairphone!
Nach dem Zusammenbau kommt kein Ton mehr heraus. Woran kann das liegen?
Remove the four 4.1mm-longPhillips #00 screws.
Use a spudger to pry up and disconnect the bottom module connecting cable.
Use your fingers to remove the bottom module.
Attention, la nappe s'est débranchée du « mauvais » côté (c'est-à-dire, du reste de l'appareil) lorsque j'ai effectué l'opération.
Il faut alors la reconnecter correctement, ce qui est un peu galère.
Hi,
When I detached the bottom module, on the little "tongue"on the tight side I found a plastic tape and I was wondering if it was normal or if I had to remove it.
Could you tell me please?
Bonjour,
avez vous pu remplacer votre partie basse ? Et où l'aviez vous achetée? Je vous remercie. Cathie
Catsilou -
Information on what to do with the old module can be found on the FairPhone support page and in the FairPhone forum.
crwdns2935229:035crwdne2935229:0
crwdns2947412:014crwdne2947412:0
Spitze, jetzt lädt mein Fairphone 3 wieder tadellos. Tolle Anleitung!!!
Super, das freut uns!
Thanks for the guide, it was very helpful. However, I'm pretty sure we don't need to remove so many screws on Step 5.
I for one had a hard time removing one, and I left it in place, and I could achieve the repair without any problem.
I think only the 6 screws on the very outside edge, that correspond with the screen's locations for the screws.
Hello @mll, thank you for sharing your experience with us! We're glad that the repair worked out. I've rechecked the display and the phone assembly. All screws should be removed to make sure not to damage components of the phone. Feel free to check Fairphone's video on replacing the display unit: https://www.youtube.com/watch?v=hG6OVPTn...
@adrianazwink , you are right indeed, and I stand corrected.
mll -
ok pour moi j'ai suivi les instruction et c'est bon
Hört sich gut an. Jedoch sind die Untermodule für das Fp3+ leider nicht mehr lieferbar, nach noch nicht mal 2 Jahren.
Haben Sie einen Tipp, wo man noch eines bekommt?
Vielen Dank Birgit
Hallo @birgitreis11702 , da gibt es aktuell leider Lieferschwierigkeiten, wir sollten aber ab September wieder welche lieferbar haben. Wenn du oben beim Ersatzteil auf "kaufen" klickst, wirst du auf die Produktseite weitergeleitet und kannst dann dort "Benachrichtige mich" aktivieren, so dass du eine Email erhälst, sobald der Artikel wieder lieferbar ist - damit hast du natürlich noch nix verbindlich gekauft, also keine Angst!
Wegen Problemen beim Laden habe ich das Modul getauscht. Der Austausch des Moduls hat mit der Anleitung super funktioniert.
Hinterher habe ich das alte Modul genauer untersucht und habe festgestellt, dass der Tausch gar nicht nötig gewesen wäre. Die Ladeprobleme wurden durch Fusseln verursacht, die sich in der Buchse festgesetzt und so den Kontakt mit dem Stecker verschlechtert haben. Bei Problemen beim Laden also erst mal die Buchse auf Verschmutzung prüfen und reinigen. :-)
Die Anleitung ist perfekt. Die Lasche des USB-C war durch einen Kabelunfall beschädigt worden. Jetzt lädt das Fairphone 3 wieder perfekt, ne Menge Geld und Resourcen gespart. Vielen Dank, Fairphone und Community!
Yeah! Very nice. Phone is charging again. And this is exactly as Fairphone Team was thinking it should be working! I used this phone for many years now. And once it broke, I just ordered a new piece and.... voilà! Very nice.
Die erste echte Reparatur seit dem 27.8.2019 (nach dem Upgrade der Kamera) und es hat noch nicht einmal 20 Minuten gedauert. Am schwierigsten war das Abheben des Display-Moduls, das hat mich einen Fingernagel gekostet ;-)
Ende gut, alles gut, jetzt lädt es wieder zuverlässig
Tolle Anleitung, damit ging der Wechsel sehr zügig. Herzlichen Dank!
Délicatement avec un tournevis plat c’est faisable aussi, à la place du médiator, mais moins prudent bien sur !
