crwdns2959928:0crwdne2959928:0 ↓Use this guide to replace the bottom module in your Fairphone 3.
Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom right of the back cover.
Pry the back cover up to start separating its plastic clips.
Slide around the bottom right corner of the back cover to loosen the lower plastic clips.
Lift the back cover to release the rest of the plastic clips and remove it.
Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
Lever the battery up until you can get a good grip.
Lift the battery out of its recess and remove it.
Remove the thirteen Phillips #00 screws (4 mm length).
Insert an opening pick between the midframe and the display module on the right edge of the phone.
Slide the opening pick down to the bottom right corner to pry open the plastic clamps of the display module.
Slide the opening pick around the bottom right corner and use it to disengage the plastic clamps at the bottom of the display module.
Slide the opening pick along the left side to pry the display module up.
Remove the four 4.1mm-longPhillips #00 screws.
Use a spudger to pry up and disconnect the bottom module connecting cable.
Use your fingers to remove the bottom module.
Information on what to do with the old module can be found on the FairPhone support page and in the FairPhone forum.
crwdns2935229:044crwdne2935229:0
crwdns2947412:014crwdne2947412:0
Spitze, jetzt lädt mein Fairphone 3 wieder tadellos. Tolle Anleitung!!!
Petra Breit - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Super, das freut uns!
Adriana Zwink - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Thanks for the guide, it was very helpful. However, I'm pretty sure we don't need to remove so many screws on Step 5.
I for one had a hard time removing one, and I left it in place, and I could achieve the repair without any problem.
I think only the 6 screws on the very outside edge, that correspond with the screen's locations for the screws.
mll - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Hello @mll, thank you for sharing your experience with us! We're glad that the repair worked out. I've rechecked the display and the phone assembly. All screws should be removed to make sure not to damage components of the phone. Feel free to check Fairphone's video on replacing the display unit: https://www.youtube.com/watch?v=hG6OVPTn...
@adrianazwink , you are right indeed, and I stand corrected.
