This is a repair guide for the bumper sensor on the Eufy Clean RoboVac G32 Pro. The bump sensor acts as a physical touch sensor that detects when the robot has collided with an obstacle, like a wall or furniture, triggering it to change direction and avoid further contact. If your RoboVac is constantly bumping into objects even when it shouldn't, or if it doesn't seem to react to obstacles at all, it's a good indication that the bumper sensor has likely gone out.
Orient the device so the underside is facing up.
Remove the eight 9.3 mm screws securing the bumper brackets using a Phillips #1 screwdriver.
Remove the bumper brackets.
Lift the bumper off of the device gently.
Use your fingers to disconnect the 8 pin connector.
Remove the two 10 mm screws using a Philips #1 screwdriver.
Lift the bump sensor off using your fingers.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
