The I/O board houses the 3.5mm plugs for an AUX input and headphone output, the USB charging plug for a smartphone, and a DC input. In the case that any of these are damaged, the entire board may need to be replaced.
Pull the plastic tab on the battery compartment cover panel to loosen it, then pull the panel off.
Disconnect the battery pack wires from the device and remove the battery pack.
On the bottom of the device case's face are two T10 screws. Use a T10 Torx screwdriver to remove the two screws.
While using the T10 screwdriver, remove the two T10 screws on the back of the device's case.
Remove the two Phillips #00 screws located in the center of the back of the device.
On the bottom of the device's case there are two rubber feet. Pry the rubber feet off of the case.
Pull the two halves of the device's case apart.
Unsolder the red and white wires where the backup batteries connect to the I/O board.
Just above the I/O board, there is a small clip securing the wire to the motherboard. Remove the Philips #1 screw and lift it up.
Remove the two Philips #1 screws that secure the I/O board to the case.
Gently lift the I/O board straight upwards to remove it.
To reassemble your device, follow these instructions in the reverse order.
You say “No parts required,” list a soldering station that you never use, and only tell us how to get the board out.
My USB Connector got ripped off the ckt board, I was hoping to find a source (parts) for the replacement board…
“In the case that any of these are damaged, the entire board may need to be replaced.”
