If the device's screen has distorted images, or is blank and the troubleshooting guides don't seem to fix it, or if the device's screen is cracked, this guide will explain how to replace it.
Inser the flat end of a spudger into one of the two notches and pry off the case.
Slide the spudger around the perimeter of the radar housing until the case separates.
Repeat these steps to remove the other side.
Remove the four 9mm Phillips #1 screws from the bottom of the radar.
Remove the bottom case.
Gently spread apart the thin silver frame that wraps around the device and remove the dark purple lens.
Push the two black tabs down to release the ribbon attached to the display.
The display ribbon should now easily slip out from under the white strip.
Hola qué tal , necesitaba comprar el display de passport detector radar
Donde puedo comprar el display de passport Max
Va aqui para display, possible…
go here for the display, possibly.
Kenye -
Se mea estallando el display
Hello, i want to buy display for my escort passport max. thank you
crwdns2947412:012crwdne2947412:0
Kelsey, Where do you get the part? I need a replacement screen for my Passport Max FB30947A3. Escort customer service won’t sell it to me and requires me to send the unit to them for a bog fee.
I also need to replace my screen and would like to know where I can get the part. Mine was dropped and the screen cracked. I do not feel like spending $139 to repair an older detector. Thanks for any info you can provide!
I need a display screen for a max 2
Where can a replacement screen be ordered?
Escort Max II screens are now available in ebay
John -
I need the display replacement part as well
I have escort max II, Replacement Lenses for sale on eBay.
John -
Did anyone figure out where to order a screen replacement for these? Looks like a simple project. Would love to fix the screen
They’re now available on eBay
There are none on ebay
No longer available on ebay and no longer repairable by escort as of summer 2021. Any ideas where to get a replacement? Is it interchangeable with other models screens?
Where can I find a replacement screen for my passport Max 2 radar detector or the part number
