Ergomixx Blender (Bosch) disassembly
  1. Ergomixx Blender (Bosch) disassembly, Head Screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The speed switch can be removed by placing it on position 3 (to be checked, we broke it without realizing it) and then pulling the switch out.
    • The 2 first screws are now visible.
    T9 Torx driver needed for all four screws...
    franklydude - crwdns2934203:0crwdne2934203:0
    On mine it was more like position 2 to allow the pegs to slide through.. Not a big issue to fix though.
  2. Ergomixx Blender (Bosch) disassembly, Case screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The last 2 screws are hidden under a small plastic cover at the bottom of the motor block.
    après toute la procédure comment enlever le capot ? il est très résistant et j’ai peur d’insister pour le soulever. merci de me donner la solution.
    christian.baskens - crwdns2934203:0crwdne2934203:0
    Ce capot est simplement emboîté. Nous l’avions soulevé, aux deux extrémités, avec une simple lame de couteau.
    Louis
    Louis Possoz -
    Push on very edge corner of the curved plastic strip with blunt screwdriver or splurgier tool and it pops out easily.
  3. Ergomixx Blender (Bosch) disassembly, GR Thermal Micro-switch: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • In our case, the thermal fuse was blown, i.e. the small white component labelled «Y51 H 120C».
    • First solution: remove the thermal fuse and place a shunt instead (a small wire). Downside: loss of the thermal protection on this "short working duration" blender.
    • Second solution: replace the thermal fuse (which is better) by a component with the same characteristics. In this case, probably with a fusing temperature of 120°C and a max. current 5A.
    • Thanks to Darr and to webpage http://elwo.ru/forum/34-1408-1 for the picture and for giving us the right hint.
    Thx dude. Replacing this Thermal cut off switch seems to have done the trick on my Bosch MSM76PRO hand blender. I replaced the Y51H120C by a TB05-BB5D-110, which works fine.
    Die Andere Knakker - crwdns2934203:0crwdne2934203:0
crwdns2934873:0crwdne2934873:0
fr en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Louis Possoz
crwdns2935283:001/10/15crwdne2935283:0
483 crwdns2915208:0crwdne2915208:0
crwdns2947412:07crwdne2947412:0
Avant tout Merci beaucoup pour ce tutoriel!
Il m’a vraiment bien servi.
Je confirme que la bonne position, pour retirer le bouton du régulateur de vitesse, est 2 ( et non 3 ).
Il faut malgré tout le retirer délicatement ( j’ai aussi cassé pour avoir tiré trop fort )
Cordialement
Lionel
Cachou - crwdns2934203:0crwdne2934203:0
Merci pour la procédure d'ouverture, mais malheureusement trop courte! Il faudrait y ajouter les 4 zones d'appui (2 par coté de jonction) pour savoir ou pousser exactement afin de libérer les verrouillages d'emboitement. J'ai pris énormément de temps pour ces zones et en douceur, j'ai réussi a libérer ces 2 pattes pour permettre l'ouverture dans la zone centrale du moteur. Personnellement c'était un fil d'alimentation cassé juste à la fin de la gaine de maintien en sortie d'appareil. panne classique si on enroule trop court le fil autour du mixeur.
Bref au total 3h pour réparer ce fil d'alimentation. (raccourci juste à la cassure)
Merci pour votre tuto
GHISLAIN DUFRANE - crwdns2934203:0crwdne2934203:0
Bonjour @ghislaindufrane C'est un plaisir d'entendre que vous avez réussi à réparer votre mixeur ! Félicitations et merci également pour le précieux retour. iFixit étant un wiki, je vous invite à mettre à jour le tutoriel pour que les suivants puissent réparer encore plus facilement. La communauté vous sera infiniment reconnaissante !
Claire Miesch -
Oui ! tres interresse de connaitre ou sont les zones d'emboitement pour pouvoir demonter. Actuellement, je suis bloque !
Olivier POVEDA - crwdns2934203:0crwdne2934203:0
Démontage mixeur Moulinex 1.2.3
Zizou Blanche - crwdns2934203:0crwdne2934203:0
Pour le démontage / remontage, voici une vidéo complète https://www.youtube.com/watch?v=D1A0oo91...
F Martens - crwdns2934203:0crwdne2934203:0
J'ai remplacé le micro interrupteur thermique y51-h-85c-b02-61920 ( 85°c – 4A) de mon mixer Bosch MSM88190 800 watts
****** par un composant équivalent TB05-BB5d-80 (80°c) acheté sur A**Z** pour 8,5 € livraison comprise !
Le mixer re-fonctionne !
Merci à Louis Possoz
crwdns2936753:07crwdne2936753:0 44
crwdns2936753:030crwdne2936753:0 251
crwdns2942667:0crwdne2942667:0 17,273
