Epson VS250 Fan Replacement
    1. Epson VS250 Fan Replacement, Shell: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Place the projector on a flat surface.
      • Orient the projector so that the the word "Epson" is facing you.
      • Using the Phillips #1 screwdriver, to loosen the screw on the top right corner of the projector. The screw only needs to be loosened.
    2. Epson VS250 Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Slide the cover to the right and lift the cover up and out to remove.
    3. Epson VS250 Fan Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using a Phillips #1 screwdriver, remove the three 6 mm screws that hold the side portion of the projector in place.
      • Use the same Phillips #1 screwdriver to remove the single 10 mm screw that is holding the side cover of the projector in place.
    4. Epson VS250 Fan Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a Phillips #1 screwdriver to remove the two 10 mm screws that are holding the side cover of the projector in place.
    5. Epson VS250 Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Epson VS250 Fan Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Flip the projector so that it lays upside down.
      • Using a Phillips #1 screwdriver, remove the eight 10 mm screws that secure the side portion of the projector.
    6. Epson VS250 Fan Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the front cover from the projector by pulling it off of the device.
    7. Epson VS250 Fan Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a Phillips #1 screwdriver to remove the two 10 mm screws.
      • After completing this step you will be able to remove the back cover from the projector.
    8. Epson VS250 Fan Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Slowly lift up the top shell up and out of the device.
      • Disconnect the ribbon cable from the motherboard and remove the shell from the device.
    1. Epson VS250 Fan Replacement, Fan: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a Phillips #1 screwdriver to remove the five 10 mm screws.
    2. Epson VS250 Fan Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Epson VS250 Fan Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Epson VS250 Fan Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Unplug the fan connector from the circuit board.
      • Remove the wires from the hooks that secure them to free the fan.
    3. Epson VS250 Fan Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Epson VS250 Fan Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Disconnect the wire and remove the black casing from the rest of the fan assembly.
    4. Epson VS250 Fan Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Epson VS250 Fan Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the fan from the device.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Warren Cutlip
crwdns2935283:009/28/21crwdne2935283:0
604 crwdns2915208:0crwdne2915208:0
Clemson, Team 4-2, Hunter Fall 2021 crwdns2935289:0Clemson, Team 4-2, Hunter Fall 2021crwdne2935289:0
CLEM-HUNTER-F21S4G2
crwdns2936753:030crwdne2936753:0 39
crwdns2942667:0crwdne2942667:0 797
