Epson Perfection V33 Glass Cleaning Process
    • Open up the lid to the flatbed scanner.
    • It can help with the next step if you lift it so it bends out flat to the other side.
  1. crwdns2935267:0crwdne2935267:0
    • On each side of the open hinge there are two large Phillips screws on either side.
    • Use a Phillips screwdriver to unscrew them and lift them out with tweezers.
    • Be careful and avoid dropping the screws on the scanning glass so you don't scratch it.
    • Gently lift the top casing of the scanner up from the side where you unscrewed the area around the lid hinge, at the corner opposite to where the buttons are located.
    • While holding it up at an angle like that, slide the casing towards the opposite side of the hinge.
    • The top casing can now be gently lifted off.
    • Use a glass cleaner (as instructed on the bottle) to clean off any fungal growths or particles off of the underside of the glass, then dry with a lint-free cloth.
    • There you go! All gone.
Caius Nocturne
crwdns2935283:007/12/21crwdne2935283:0
2,106 crwdns2915208:0crwdne2915208:0
crwdns2935297:013crwdne2935297:0
crwdns2936753:030crwdne2936753:0 37
crwdns2942667:0crwdne2942667:0 647
