Electrical Plug Replacement
Tim Spellings
crwdns2944107:0crwdnd2944107:0Tim Spellingscrwdnd2944107:0crwdnd2944107:0crwdnd2944107:010crwdnd2944107:0crwdne2944107:0
crwdns2944111:0January 15, 2024crwdne2944111:0
15 - 30 crwdns2931279:0crwdne2931279:0
crwdns2937801:0crwdne2937801:0
crwdns2942287:0crwdne2942287:0
A common issue with electronic devices is a severed or damaged wire. Whether a dog chews through a wire, a child playing with scissors cuts a wire, or a large appliance slices through a wire, many have encountered this problem. This guide teaches how to remove a damaged plug and replace it with a new plug. The wiring in the lamp plug must be done correctly in order for the lamp to turn on after the repair is finished. This guide shows how to properly locate the "hot" and "neutral" connections.
crwdns2944105:0crwdne2944105:0
  1. Electrical Plug Replacement, Two-Pole Plug: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Electrical Plug Replacement, Two-Pole Plug: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Be sure to unplug the lamp.
    • Locate the damaged portion of wire.
    • Cut the damaged plug from the lamp cord one inch below the damaged area
  2. Electrical Plug Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Electrical Plug Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Separate the wire by gently pulling it apart.
    • The wire with the raised ribbing on the coating is the neutral wire.
    • The hot wire has a smooth coating.
  3. Electrical Plug Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Electrical Plug Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Electrical Plug Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Strip the coating off the wire.
    • Expose 3/4" of the copper wire.
    • Twist the exposed copper wire so that there is no fraying.
    • Twisting the wires ensures the strongest connection and maximum safety.
  4. Electrical Plug Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Electrical Plug Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Loosen the screw and open the replacement plug.
    • The silver screw is the neutral connection, and the brass screw is the hot connection.
    • The different connections must be determined in order to properly wire the replacement plug.
  5. Electrical Plug Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Electrical Plug Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Electrical Plug Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Wrap the neutral wire around the neutral screw. Tighten the screw to secure the wire.
    • Remember the neutral wire is the wire with raised ribbing on the coating.
    • Wrap the hot wire around the brass screw. Tighten the screw to secure the wire.
  6. Electrical Plug Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Electrical Plug Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Thread the cord so the plug will completely close.
    • Tighten the exterior screw to close the plug.
    Where can I purchase a new plug
    Marlene4950 - crwdns2934203:0crwdne2934203:0
    You can purchase it at almost every hardware store.
    Toon Konings - crwdns2934203:0crwdne2934203:0
If the lamp the does not work after replacing the plug, the issue may be located in the bulb housing or in the connections.
crwdns2935229:018crwdne2935229:0
Tim Spellings
crwdns2935283:007/17/15crwdne2935283:0
571 crwdns2915208:0crwdne2915208:0
Texas Tech, Team 3-2, Rauch SU 2015 crwdns2935289:0Texas Tech, Team 3-2, Rauch SU 2015crwdne2935289:0
TTU-RAUCH-SU15S3G2
crwdns2947412:07crwdne2947412:0
A version for 3 prong (North American) would be great
James Harrison - crwdns2934203:0crwdne2934203:0
https://www.noveltylights.com/coaxial-6-...
How would you repair a coaxial cord wire right where it enters the screw on part?
olgaocon - crwdns2934203:0crwdne2934203:0
what do you do if the replacement plug has no screws to open it?
Kristin Ladd - crwdns2934203:0crwdne2934203:0
Buy a plug that can be opened with a screw
Toon Konings -
How can you tell hot wire from neutral wire?
Dr. Karakas - crwdns2934203:0crwdne2934203:0
the neutral wire usually has raised ribbing on its sleeve, and the hot wire has a smooth rubber sleeve. (See Step 2 of the guide)
Ben Eccles -
crwdns2936753:07crwdne2936753:0 62
crwdns2936753:030crwdne2936753:0 260
crwdns2942667:0crwdne2942667:0 49,530
