Ego battery lawn mower safety switch connector replacement
  1. Ego battery lawn mower safety switch connector replacement, Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery
    • Get a container to hold all the screws you will be removing. There are many!
    • Remove the 6 screws that hold the battery box in place. Use a marking pen to indicate the colors of the 3 wires connected to the battery box. (red, blue, black)
    • Disconnect the ribbon cable from the bottom of the control panel where the headlight switch and warning lamps are located.
    • Turn the mower on its side and remove the blade.
    • Remove all the screws from the bottom panel of the mower.
    • Remove the height adjustment knob
    • Remove the top cover. If it isn't coming off, check to see if you've removed all the screws.
    • Use a small clamp to push down the safety switch that detects that the top cover has been removed. The mower will not run if this switch isn't pushed.
    • Extend the mower handle to the operating position. The mower will not run if handle isn't extended. There's a micro switch in the handle latch assembly, on the side with the cable.
    • Connect the battery box. Be sure to put the correct wires on each of the 3 terminals.
    • Insert the battery. Push down hard until it clicks.
    • Start the mower with the handle switch.
    • Locate the 3-wire cable and connector on the logic board that connects to the safety switch in the handle. (See the video) Wiggle this cable to see if the motor starts or stops.
  2. Ego battery lawn mower safety switch connector replacement, Replace the connector: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ego battery lawn mower safety switch connector replacement, Replace the connector: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ego battery lawn mower safety switch connector replacement, Replace the connector: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Check that the replaced connector is working correctly, using the same process used in the diagnosis step.
    • Reassemble the mower.
Wayne Seltzer
crwdns2935283:011/09/10crwdne2935283:0
1.811 crwdns2915208:0crwdne2915208:0
crwdns2947412:010crwdne2947412:0
I blew it I did not mark the order of the three wires connecting the battery. Can you help. Is it red black blue?
Abraham Chapman - crwdns2934203:0crwdne2934203:0
Sorry, my only documentation of my repair project are the photos I’ve posted here. Maybe you can obtain a service manual from the manufacturer?
Wayne Seltzer -
The micro on my mower is ok, mover wont start. Do you know what voltage through the on switch should be? Mine appears to be 20 v, should it be 56v?
Barry Bennett - crwdns2934203:0crwdne2934203:0
Sorry, but I never measured the voltage across the safety switch. Good luck with your troubleshooting!
Wayne Seltzer -
My EGO often stops running even when fully charged, and especially when it goes over uneven ground. It seems like perhaps the battery comes slightly loose, although it doesn't pop out or even look like it's out of place.
Does it sound like its problem is the one you've addressed here?
Lee Penya - crwdns2934203:0crwdne2934203:0
It could be. The safety switch connector is a poor design and the mower vibration causes the connection to intermittently fail.
Wayne Seltzer -
Hi, my EGO Mower has developed a fault, when i insert the battery the motor starts up without even touching the safety handle or pushing the start switch.
Where should I investigate first, or what is the most likely cause of this?
Any advice would be much appreciated
dr breaks - crwdns2934203:0crwdne2934203:0
Uh oh! That's a serious safety hazard.
Have you contacted Ego support? I'm sure that would want to know about this!
And, I'm sure we're all interested in hearing their response.
- Wayne
Wayne Seltzer -
il mio tosaerba EGO elettrico per colpa di una alluvione è finito interamente sotto acqua e fango , ora non parte piu cosa posso fare ? grazie (valeevange@outlook.it)
VALERIANO EVANGELISTA - crwdns2934203:0crwdne2934203:0
Wayne Seltzer - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 19
crwdns2936753:07crwdne2936753:0 114
crwdns2936753:030crwdne2936753:0 326
crwdns2942667:0crwdne2942667:0 28,402
