Echo Chain Saw CS4910 2020 Clutch Assembly Replacement
  1. Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Turn off the chainsaw: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Turn off the chainsaw: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Make sure you have the ignition switch turned off before starting your repair.
    • The chainsaw should be cool to the touch before continuing.
  2. Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Loosen the air filter cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Loosen the air filter cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to loosen the air filter cover knob.
  3. Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Remove the air filter cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Remove the air filter cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Remove the air filter cover: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the air filter cover.
  4. Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Remove the air filter: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Remove the air filter: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Remove the air filter: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • During reassembly, clean the air filter with compressed air or with light brushing before reinstalling it.
  5. Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Disconnect the spark plug: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Disconnect the spark plug: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Disconnect the spark plug: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to pull up and disconnect the spark plug boot.
  6. Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Loosen the sprocket guard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Loosen the sprocket guard: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a 13 mm wrench to loosen and remove the two nuts securing the sprocket guard.
  7. Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Remove the sprocket guard: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Remove the sprocket guard: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Remove the sprocket guard: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the sprocket guard straight off its two pegs and remove it.
  8. Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Unclip the saw chain: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Unclip the saw chain: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Put on gloves before performing the next two steps.
    • Pull the saw chain away from the tip of the guide bar to unclip it.
  9. Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Remove the guide bar: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Remove the guide bar: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Remove the guide bar: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push the guide bar towards the back of the device to unclip the rest of the saw chain.
    • Pull the guide bar away from the device to separate the saw chain from the clutch drum.
    • Remove the guide bar and the saw chain.
  10. Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Unfasten the bumper spike: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Unfasten the bumper spike: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T25 Torx driver to remove the two 17 mm-long screws securing the bumper spike.
  11. Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Remove the bumper spike: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Remove the bumper spike: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the bumper spike away from the chassis and remove it.
  12. Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Unfasten the inner guide plate: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Unfasten the inner guide plate: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two screws securing the inner guide plate:
    • Use a Phillips driver to remove the 8 mm-long screw.
    • Use a T25 Torx driver to remove the 33 mm-long screw.
  13. Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Remove the inner guide plate: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Remove the inner guide plate: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Remove the inner guide plate: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the inner guide plate straight off its two pegs and remove it.
  14. Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Unfasten the brake cover: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Unfasten the brake cover: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a 2.5 mm hex key to remove the three 14 mm-long screws securing the brake cover.
  15. Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Remove the brake cover: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Remove the brake cover: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Remove the brake cover: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the brake cover straight off the chassis and remove it.
    • Make sure the chain brake is in the disengaged position before continuing.
  16. Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Unfasten the chain brake handle: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Unfasten the chain brake handle: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a 4 mm hex key to remove the two screws securing the chain brake handle:
    • One 19 mm-long screw
    • One 23 mm-long screw
  17. Echo Chain Saw CS4910 2020 Clutch Assembly Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS4910 2020 Clutch Assembly Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS4910 2020 Clutch Assembly Replacement: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Rotate the chain brake handle towards the guide bar recess to unhook the brake lever.
    • Pull the handle away from the chassis to completely remove it.
  18. Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Unfasten the chain brake assembly: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Unfasten the chain brake assembly: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips driver to remove the 8 mm-long screw securing the chain brake assembly.
  19. Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Remove the chain brake assembly: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Remove the chain brake assembly: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Remove the chain brake assembly: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Be careful with this step, as there's tension within the spring. Work slowly to avoid the spring from ejecting.
    • While holding the spring with one hand, slowly push the brake lever out of its recess until the spring is fully extended.
    • Remove the chain brake assembly.
    • During reassembly, insert the spring into its recess first and compress it enough to reinsert the brake lever.
  20. Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Remove the retaining plate: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Remove the retaining plate: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Remove the retaining plate: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the retaining off the chassis and remove it.
  21. Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Remove the torsion spring: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Remove the torsion spring: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Remove the torsion spring: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the torsion spring off the chassis and remove it.
  22. Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Remove the collar: crwdns2935265:022crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Remove the collar: crwdns2935265:022crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Remove the collar: crwdns2935265:022crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a flathead screwdriver to pry the collar out of its recess.
    • Remove the collar.
  23. Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Unfasten the engine cover: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Unfasten the engine cover: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a flathead screwdriver, or a 3 mm hex key, to remove the three 18 mm screws securing the engine cover.
  24. Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Remove the engine cover: crwdns2935265:024crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Remove the engine cover: crwdns2935265:024crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Remove the engine cover: crwdns2935265:024crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the engine cover straight up off the engine.
    • Remove the engine cover.
  25. Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Loosen the spark plug: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Loosen the spark plug: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spark plug socket to loosen the spark plug.
  26. Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Remove the spark plug: crwdns2935265:026crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the spark plug.
  27. Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Insert a rope: crwdns2935265:027crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Insert a rope: crwdns2935265:027crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Insert a rope: crwdns2935265:027crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a piston stopping cord or rope through the cylinder head into the combustion chamber until the crankshaft can no longer turn over.
    • Do not insert the entire cord into the combustion chamber.
  28. Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Remove the clutch drum nut: crwdns2935265:028crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Remove the clutch drum nut: crwdns2935265:028crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a 13 mm wrench to loosen and remove the clutch drum nut.
    Note: The 13 mm. clutch drum nut is removed by turning it clockwise.
    Woodrow Williams - crwdns2934203:0crwdne2934203:0
  29. Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Free the clutch drum: crwdns2935265:029crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Free the clutch drum: crwdns2935265:029crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Free the clutch drum: crwdns2935265:029crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the washer.
    • Remove the rim sprocket.
  30. Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Remove the clutch drum: crwdns2935265:030crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Remove the clutch drum: crwdns2935265:030crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the clutch drum straight off the clutch assembly to remove it.
  31. Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Remove the clutch assembly: crwdns2935265:031crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Remove the clutch assembly: crwdns2935265:031crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a clutch removal tool to loosen the clutch assembly.
    • Rotate the wrench clockwise instead of counter-clockwise.
  32. Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Remove the clutch assembly: crwdns2935265:032crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Echo Chain Saw CS4910 2020 Clutch Assembly Replacement, Remove the clutch assembly: crwdns2935265:032crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the clutch assembly.
Alex Diaz-Kokaisl
crwdns2935283:001/16/22crwdne2935283:0
173.848 crwdns2915208:0crwdne2915208:0
crwdns2935297:0798crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021.719crwdne2935297:0
In step 28 where you are removing the nut that holds the clutch drum on which direction is the nut turned to remove it?
Hi there!
It should be the normal counterclockwise movement to loosen that nut.
Alex Diaz-Kokaisl -
I have lossen the nut, it turns but does not come off. Do you know what it might be?
Svyatoslav Bogatyrev - crwdns2934203:0crwdne2934203:0
Why did you remove the engine cover and chain brake assembly?
Posi X Mosh - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 48
crwdns2942667:0crwdne2942667:0 2,420
