EasySMX ESM-9100 Face Buttons Replacement
  1. EasySMX ESM-9100 Face Buttons Replacement, Bottom Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the controller face down on a solid surface.
    • Use a Phillips #00 screwdriver to remove the seven 10 mm screws from the back cover.
    • The order does not matter.
  2. EasySMX ESM-9100 Face Buttons Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 EasySMX ESM-9100 Face Buttons Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 EasySMX ESM-9100 Face Buttons Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the iFixit opening tool to pry off the back cover and remove it to reveal the internal components.
    • Place the cover off to the side, then grab the circuit board and gently remove it from the front cover.
    • Be careful when removing the back cover, the components in this controller are loosely attached and can fall out easily.
  3. EasySMX ESM-9100 Face Buttons Replacement, A/B/X/Y Buttons: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 EasySMX ESM-9100 Face Buttons Replacement, A/B/X/Y Buttons: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull out the buttons by the rubber backing from the top cover.
    • Be gentle so the buttons don't fall off the rubber back as you pull it out.
  4. EasySMX ESM-9100 Face Buttons Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 EasySMX ESM-9100 Face Buttons Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull each face button off of the rubber backing.
    • The buttons should be on the rubber in order of Y at the top, B to the right, A at the bottom, and X to the left.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Alex Vala
crwdns2935283:003/19/24crwdne2935283:0
837 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 4-4, Shaddix Spring 2024 crwdns2935289:0UMass Dartmouth, Team 4-4, Shaddix Spring 2024crwdne2935289:0
UMASSD-SHADDIX-S24S4G4
crwdns2936753:030crwdne2936753:0 41
crwdns2942667:0crwdne2942667:0 924
