Easier way to open
  1. Easier way to open, Open the balance: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Since it is not important in the balance to get the adhesive surfaces take a beveled spatula. It's much easier and faster.
  2. Easier way to open: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Easier way to open: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Contrary to the other instructions, the board is located directly on the plastic housing. Through the 3 holes water gets into the balance and through the adhesion it spreads over the complete underside of the board
    • The Libra continues to change. Only this time too much water had penetrated which had spread under the board.
    • Clean the underside of the board with acetone. Alternatively, isopropanol.
    • After the board was dry, the scales spoke to me again. And so that water does not penetrate again, I taped the holes with silicone
    • Finally, glue the round cap to the glass plate with a little silicone glue. Because even if the board has a silicone protective coating, it would not be good if Wassser came from above on the SMD components.
Repeat the steps in order to reassemble your device.
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Marina
crwdns2935283:010/12/17crwdne2935283:0
115 crwdns2915208:0crwdne2915208:0
this does not tell you how to open it, only to use a spatula. this is not a guide, it is a waste of time.
David Hopkins - crwdns2934203:0crwdne2934203:0
I support the opinion expressed above. waste of time...
A K - crwdns2934203:0crwdne2934203:0
The 4 load cells are glued to the glass plate.
This means you only have to cut through the adhesive pads from the side
Marina -
crwdns2936753:030crwdne2936753:0 51
crwdns2942667:0crwdne2942667:0 3,086
