Dyson DC14 Power Cord Replacement
  1. Dyson DC14 Power Cord Replacement, Power Switch: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dyson DC14 Power Cord Replacement, Power Switch: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Start with your Dyson DC14 unplugged, standing upright and facing towards you.
    • Remove the canister from the vacuum.
    • Disconnect the telescopic vacuum wand.
    • Remove the two T15 Torx screws securing the switch cover to the vacuum.
  2. Dyson DC14 Power Cord Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dyson DC14 Power Cord Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push outward on the two plastic clips that secure the switch cover to the vacuum.
    There are also two screws ( one of which can been seen on the photo and another a few inches below ) that need to be removed BEFORE pushing outward on the plastic tabs.
    martyn.lockhart - crwdns2934203:0crwdne2934203:0
    There is a third clip below the lower screw.
    Clive Street - crwdns2934203:0crwdne2934203:0
  3. Dyson DC14 Power Cord Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the switch cover from the vacuum.
    • The purple switch button may separate from the rest of the switch cover.
  4. Dyson DC14 Power Cord Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Holding them by their white plastic coverings, firmly pull the two wires from the power switch.
    • Be sure to grip the wires from their attached connectors. Pulling directly on the wires could damage your vacuum.
    • The terminals will only fit one way during reassembly. Only one of the wires is long enough to reach the far terminal of the switch.
    I can’t unplug the old starter. It seems stuck. What am I doing wrong?
    Jane Wells - crwdns2934203:0crwdne2934203:0
    I can’t unplug old starter from dyson dc14. Seems stuck. Help please
  5. Dyson DC14 Power Cord Replacement, Power Cord: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the other terminal for the power cord that connects to the terminal below the power switch.
    • Holding them by their connectors, separate the remaining wire of the power cord from the internal power cable.
crwdns2935229:016crwdne2935229:0
Donald Percivalle
crwdns2935283:010/03/12crwdne2935283:0
1.952 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 3-22, Amido Fall 2012 crwdns2935289:0Cal Poly, Team 3-22, Amido Fall 2012crwdne2935289:0
CPSU-AMIDO-F12S3G22
crwdns2947412:05crwdne2947412:0
thanks, Just the basic instructions I needed.
debpet666 - crwdns2934203:0crwdne2934203:0
What a great site! Easy to follow instructions. My part fit perfectly. I booked marked you site and will be back when necessary. Thank y’all
Jerry Chastine - crwdns2934203:0crwdne2934203:0
Definitely helpful
Allen wrench works fine.
No need to buy Torx screwdriver
tacsfs - crwdns2934203:0crwdne2934203:0
I was able to remove the terminals from the power cord but am not sure how to remove the connectors from the wires. I am guessing I need to remove these connectors to get the old power cord and then use the connectors with the new wires.
carrikenney - crwdns2934203:0crwdne2934203:0
Hello, I have been given a Dyson DC 14 and it looks like the plug has been chopped off clean all the way at the very end of the Court. I would like to replace the plug or the entire cord if that's the case. But I am wondering if I do replace the cord and spend that type of money how do I know if it's going to work or not? So is there a way to test the vacuum with my car battery by touching the two cords to the terminals? also which cord is positive and which cord is negative cuz there's a black and a white cord? I have always wanted a Dyson vacuum. It is actually been a dream of mine because I think they're so cool. So now that I have one I want to fix it as inexpensively as possible. Please help thank you so much Brian Higgins
BRIAN HIGGINS - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 58,312
