This guide helps open the device and get to the screen to replace it.
Remove battery.
Remove the label cassette.
Remove the 6 screws in the indicated places. These particular screws are 2mm x 8mm Phillips #0 head
Use the spudger to take apart the device by insterting it as shown in the picture and twisting it. This should be done all around the device to ensure the two parts split correctly.
Further remove the 2 screws (1.2mm X 4mm Phillips #0 head).
Hi where do I get a screen? And what sort am I looking for?
Hi, thak you for the tutorial, it seems pretty simple. Do you know where to find the LCD screen, or whats the specs, maybe I can find it at AliExpress.
