Drobo FS DRDS2-A Power Switch Replacement
crwdns2942287:0crwdne2942287:0How to replace the Power Switch
crwdns2944105:0crwdne2944105:0
To start getting the case off remove the front panel so it's out of the way.
Next remove the screws from the feet of the case with a phillips head screwdriver.
To remove the case, place the Drobo on its back and slide the case off.
Press tabs to release back cover and lift off
Push tabs in and carefully pull out the front facer and drive shelves
Unscrew the back face by removing the screw on the back sides, then slide top face apart from the others
Carefully unplug the Power Switch and Fan wires.
Press tabs on Power Switch to release the Power Switch and Push out.
Finally pull the old switch out and pop the new one in.
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0crwdns2947412:05crwdne2947412:0
Hello,
great info I found here, but where do I buy a replacement button for my Drobo in Europe?
Kind regards and thank you in advance,
Heinrich
Hi, where do I find a replacement power switch for my Drobo 5N? BTW, thanks for the great tutorial!
I took my Drobo apart and the printed numbers on the switch are R13-112. I ordered these on Amazon:
https://www.amazon.com/Twidec-Rocker-Tog...
I put it in, crossed my fingers, and BAM, worked like a charm. Hope that helps all the future DIY’ers.
Good article - thanks. Discovered my Drobo 5N (cir 2014) has a 3-wire spring-loaded switch with 2V LED (green) (wires: Red - White - Blue) Press once to turn on; Press and hold to manually turn off. Can simple R13-112 SPST switch be substituted?
Many thanks Rye. My Drobo 5C switch has been playing up for a while and your article gave me the courage to tackle the issue. A few dirfferences for the 5C (removing the back panel) but otherwise all tickety boo.
