Dremel 8200 Disassembly
crwdns2942287:0crwdne2942287:0Disassembling your Dremel 8200.
Take off the screw cap at the top
The casing should just open right up and be easily accessible
You can remove the buttons except for the sliding one that adjusts the speed
Work your way down and take out each successive circuit board
The last thing to be out should be the sliding speed adjustment and the button for that should fall right out
It will be handy to have either a can of compressed air or an air directional nozzle on your compressor. Be careful of the circuits and small parts that can blow away. You'll be amazed how even with a maintenance schedule, how much dirt will be on the motor fins
How do you replace just the bearing in this assembly?
