Doss E-GO II Charging Port Replacement
  1. Doss E-GO II Charging Port Replacement, Charging Port: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Doss E-GO II Charging Port Replacement, Charging Port: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Doss E-GO II Charging Port Replacement, Charging Port: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel the backing off of the speaker.
    • Remove eight 7.9 mm screws using the Phillips #00 screwdriver.
    • Gently pull apart the grille on the sides of the speaker.
  2. Doss E-GO II Charging Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Doss E-GO II Charging Port Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Doss E-GO II Charging Port Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove four 7.8 mm screws using the Phillips #00 screwdriver.
    • Pull out the charging port and remove the two 7.8 mm screws using the Phillips #00 screwdriver.
    • Apply a bead of flux.
  3. Doss E-GO II Charging Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Press the soldering iron tip firmly to melt the solder.
    • If you heat the area for more than 10 seconds, the excessive heat may damage the board, port, and wires.
    • Use tweezers to remove the charging port.
Natalie
crwdns2935283:002/25/25crwdne2935283:0
355 crwdns2915208:0crwdne2915208:0
Idaho State University, Team 1-6, Watkins Spring 2025 crwdns2935289:0Idaho State University, Team 1-6, Watkins Spring 2025crwdne2935289:0
ISU-WATKINS-S25S1G6
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 100
