This guide will instruct users how to replace a door frame's damaged strike plate. This will allow for the door's lock to catch onto the strike plate.
A strike plate might need to be replaced because it is too damaged to properly work. If the door's lock is not catching onto the strike plate and firmly staying in place, the strike plate may need to be replaced.
With a screwdriver, remove the two screws holding the strike plate in place.
Remove the damaged strike plate from the door frame.
Replace the damaged strike plate with a new strike plate.
The holes of the new strike plate should align with the holes of the damaged strike plate. If they do not, new holes on the door frame would need to be drilled.
Apply the new strike plate to the frame of the door, and ensure that the strike plate's holes are aligned with the drilled-in holes on the door frame.
Screw in the top screw first, ensuring that the strike plate will remain in place. Then, screw in the bottom screw.
Ensure that the strike plate is not loose by trying to wiggle the strike plate with your hand.
If the strike plate budges, continue screwing in the screws until it does not budge.
How do I fill the old hole as my new plate does not line up ?
This is the real question. Idealized scenarios where everything fits together are not the most helpful ones.
Ted Rust -
