Door Frame Strike Plate Replacement
  1. Door Frame Strike Plate Replacement, Strike Plate: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With a screwdriver, remove the two screws holding the strike plate in place.
    • The screwdriver used during this guide will vary due to the size of the pre-existing screws.
  2. Door Frame Strike Plate Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the damaged strike plate from the door frame.
    • Depending on the type of strike plate, the strike plate may not remain in place after removing both of the screws.
  3. Door Frame Strike Plate Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Replace the damaged strike plate with a new strike plate.
    • The holes of the new strike plate should align with the holes of the damaged strike plate. If they do not, new holes on the door frame would need to be drilled.
  4. Door Frame Strike Plate Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply the new strike plate to the frame of the door, and ensure that the strike plate's holes are aligned with the drilled-in holes on the door frame.
  5. Door Frame Strike Plate Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Screw in the top screw first, ensuring that the strike plate will remain in place. Then, screw in the bottom screw.
  6. Door Frame Strike Plate Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Ensure that the strike plate is not loose by trying to wiggle the strike plate with your hand.
    • If the strike plate budges, continue screwing in the screws until it does not budge.
Brandon Cline
crwdns2935283:001/30/18crwdne2935283:0
133 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team S27-G6, Crane Winter 2018 crwdns2935289:0Eastern Washington University, Team S27-G6, Crane Winter 2018crwdne2935289:0
EWU-CRANE-W18S27G6
How do I fill the old hole as my new plate does not line up ?
DeniseB - crwdns2934203:0crwdne2934203:0
This is the real question. Idealized scenarios where everything fits together are not the most helpful ones.
Ted Rust -
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 84
crwdns2942667:0crwdne2942667:0 5,769
