Diswoe Switch-01 Joystick Cover Replacement
  1. Diswoe Switch-01 Joystick Cover Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Diswoe Switch-01 Joystick Cover Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Diswoe Switch-01 Joystick Cover Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips screwdriver to remove the two screws at the bottom of the hand grips.
    • Remove the handgrips from the controller.
  2. Diswoe Switch-01 Joystick Cover Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Diswoe Switch-01 Joystick Cover Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Diswoe Switch-01 Joystick Cover Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the controller over so the bottom is facing up.
    • Use a Phillips screwdriver to remove the five screws from the back case.
  3. Diswoe Switch-01 Joystick Cover Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Diswoe Switch-01 Joystick Cover Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Diswoe Switch-01 Joystick Cover Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use both hands to carefully remove the back cover.
    • For help removing the back cover, use a spudger to pry along the seam between the top and bottom case.
    • Don't pull the back cover off quickly or forcefully as the wires that are connected are easy to break.
  4. Diswoe Switch-01 Joystick Cover Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Diswoe Switch-01 Joystick Cover Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Diswoe Switch-01 Joystick Cover Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push on alternating sides of the battery connector to "walk" it out of its socket.
    • It may take a lot of alternating before the connector comes out. Be patient, and don't pull on the cables.
    • If that doesn't work, use a pair of tweezers to firmly grip the sides of the connector and pull straight away from the socket. Hold the tweezers closer to the connector to get a better grip.
    • Additionally, if the previous step didn’t work, use the arms of a pair of sharp tweezers to gently push the connector out of its socket by inserting them into the cutouts.
    • If you're having trouble, try rocking the connector side-to-side to loosen it.
    • To reconnect the cable, insert the connector into its socket and push on the edges until it's fully seated
  5. Diswoe Switch-01 Joystick Cover Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Diswoe Switch-01 Joystick Cover Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery from the main circuit board.
    • The battery is held in place by sticky foam. If you aren't able to remove it easily by hand, use a spudger to gently loosen the adhesive and then remove the battery.
  6. Diswoe Switch-01 Joystick Cover Replacement, Joystick Cover: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Next you will remove the PCB that is slotted in where the triggers are located and as well as the motors that are at the bottom of the controller
    • With everything disconnected we are able to remove the motherboard completely without any issues
  7. Diswoe Switch-01 Joystick Cover Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the motherboard completely removed we can start to clean the underside of the joystick to clean out any debris that can cause stick drift by using dust cleaner or compressed air
    • It isn’t necessary but it is highly recommended in order to get the best results
    • Once the cleaning is done you’ll reassemble the controller and calibrate it on the systems software
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Freili Estrada
crwdns2935283:009/09/24crwdne2935283:0
106 crwdns2915208:0crwdne2915208:0
CSU Los Angeles, Team 2-3, Kershman Fall 2024 crwdns2935289:0CSU Los Angeles, Team 2-3, Kershman Fall 2024crwdne2935289:0
CSULA-KERSHMAN-F24S2G3
crwdns2942667:0crwdne2942667:0 303
