Diswoe Switch-01 Battery Replacement
crwdns2869540:0crwdne2869540:0: 743
0
11
74
743
crwdns2959984:0crwdne2959984:0: 2
crwdns2959974:02crwdne2959974:0
crwdns2955944:0crwdne2955944:0: 15 - 30 crwdns2931279:0crwdne2931279:0
If you need to replace the battery of your Diswoe Switch-01 controller, follow this guide. Make sure it is disconnected from the console before you begin the repair.
    1. Diswoe Switch-01 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Diswoe Switch-01 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Diswoe Switch-01 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a Phillips screwdriver to remove the two screws at the bottom of the hand grips.
      • Remove the handgrips from the controller.
    2. Diswoe Switch-01 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Diswoe Switch-01 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Diswoe Switch-01 Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Turn the controller over so the bottom is facing up.
      • Use a Phillips screwdriver to remove the five screws from the back case.
    3. Diswoe Switch-01 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Diswoe Switch-01 Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Diswoe Switch-01 Battery Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use both hands to carefully remove the back cover.
      • For help removing the back cover, use a spudger to pry along the seam between the top and bottom case.
      • Don't pull the back cover off quickly or forcefully as the wires that are connected are easy to break.
    4. Diswoe Switch-01 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Diswoe Switch-01 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Diswoe Switch-01 Battery Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Push on alternating sides of the battery connector to "walk" it out of its socket.
      • It may take a lot of alternating before the connector comes out. Be patient, and don't pull on the cables.
      • If that doesn't work, use a pair of tweezers to firmly grip the sides of the connector and pull straight away from the socket. Hold the tweezers closer to the connector to get a better grip.
      • Additionally, if the previous step didn’t work, use the arms of a pair of sharp tweezers to gently push the connector out of its socket by inserting them into the cutouts.
      • If you're having trouble, try rocking the connector side-to-side to loosen it.
      • To reconnect the cable, insert the connector into its socket and push on the edges until it's fully seated
    5. Diswoe Switch-01 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Diswoe Switch-01 Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the battery from the main circuit board.
      • The battery is held in place by sticky foam. If you aren't able to remove it easily by hand, use a spudger to gently loosen the adhesive and then remove the battery.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Jonathan Bautista
crwdns2935283:009/25/24crwdne2935283:0
251 crwdns2915208:0crwdne2915208:0
CSU Los Angeles, Team 2-3, Kershman Fall 2024 crwdns2935289:0CSU Los Angeles, Team 2-3, Kershman Fall 2024crwdne2935289:0
CSULA-KERSHMAN-F24S2G3
crwdns2935297:036crwdne2935297:0
crwdns2936753:030crwdne2936753:0 74
crwdns2959996:0crwdne2959996:0 743
