Dismantle Nespresso CitiZ
  1. Dismantle Nespresso CitiZ, Dismantle Nespresso CitiZ: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Never forget: pull the plug!
    • Remove all attachments: Water tank, capsule and cup drawer, drip tray.
    • The model shown is also equipped with a milk frother, remove that too.
  2. Dismantle Nespresso CitiZ: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dismantle Nespresso CitiZ: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    iFixit Precision 4 mm Screwdriver Bit
    $2.99
    • The bottom is secured by oval head screws.
    • These screws have an oval head that makes them look like rivets (picture 2). You need to use a special bit - also available at iFixit - for their removal. Here a DIY guide. If the right bit is not available, it could be done with a pair of needle nose pliers. Nespresso wants to keep us out of our own machines!!!
    • Remove five oval head screws securing the large bottom panel.
    • Note: this panel is smaller on models without milk frother.
  3. Dismantle Nespresso CitiZ: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dismantle Nespresso CitiZ: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dismantle Nespresso CitiZ: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The bottom panel is just snapped into place. Insert a metal spudger into the slots and lift the panel out. It sits quite tightly and you might use some force to get it out.
  4. Dismantle Nespresso CitiZ: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the large bottom panel.
  5. Dismantle Nespresso CitiZ: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to slide off the two silicon tubes.
  6. Dismantle Nespresso CitiZ: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dismantle Nespresso CitiZ: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the two spade plugs on the blue and brown wires from the power switch. The two left ones remain.
  7. Dismantle Nespresso CitiZ: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove four oval head screws from the small bottom panel.
    • Remove the main device from the base. It´s still connected with some wires, but this doesn´t bother much.
  8. Dismantle Nespresso CitiZ: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dismantle Nespresso CitiZ: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dismantle Nespresso CitiZ: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The two colored side panels are only snapped into place. However, the latches sit very tight. You really need a lot of force. First lift the lower edge using a plastic opening tool.
    • Depending from the model it might help, when you first pry off the coffee spout. (See next step)
    • Unfold each of the side panels upwards and remove them.
  9. Dismantle Nespresso CitiZ: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert a opening tool in the gap on the bottom of the coffee spout. Pry it off carefully.
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934883:0VauWehcrwdne2934883:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
VauWeh
crwdns2935283:010/19/15crwdne2935283:0
293,806 crwdns2915208:0crwdne2915208:0
crwdns2935297:0303crwdne2935297:0
Wie geht es weiter um an die Heizung zu kommen? Vermutlich ist eine Reperatur nicht möglich.
Martin Gastberger - crwdns2934203:0crwdne2934203:0
Ich denke der Teardown zeigt es: Nespresso CitiZ Teardown
VauWeh -
crwdns2936751:024crwdne2936751:0 12
crwdns2936753:07crwdne2936753:0 129
crwdns2936753:030crwdne2936753:0 610
crwdns2942667:0crwdne2942667:0 20,462
