Disassembling the Saeco Exprelia
  1. Disassembling the Saeco Exprelia, remove back cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all accessory parts like the water reservoir, the brewing assembly as well as the drip try.
    • Remove all coffee beans from the bean container
    • Always remove the power cord
    • Remove the two T10 Torx screws from the bottom of the rear cover.
  2. Disassembling the Saeco Exprelia: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the back cover approximately 1 cm (3/8inch) out from the bottom and push it in an upward direction.
  3. Disassembling the Saeco Exprelia, rear frame: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling the Saeco Exprelia, rear frame: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the five T10 Torx screws as marked
    • the back frame consist of 3 pieces. Lift the top part out first, then each one of the side pieces
  4. Disassembling the Saeco Exprelia, top cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling the Saeco Exprelia, top cover: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling the Saeco Exprelia, top cover: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the bean compartment lid and loosen the Torx T10 screw.
    • Open the water compartment lid and loosen the Torx T10 screw.
    • The lid is locked into place several times. Carefully loosen the catches and lift off the lid.
    • Note: If you only want to remove the left cover on the water compartment, all you need to do is loosen the cover a little and lift it up by about 2 cm.
    War sehr gut beschrieben. Konnte alles gut nachvollziehen. Nur das Ausrasten des Deckels war etwas schwieriger. Ein Kabel was nicht mit erwähnt wurde , war am Deckel befestigt. Wozu? Vielen Dank.
    Wolfgang Reimann - crwdns2934203:0crwdne2934203:0
    how is it ‘locked in place 3times and where are the catches?
    Martin Klest -
    Look at picture 3
    VauWeh -
    Der Deckel auf der Wassertankseite ist ja easy anzuheben. Warum auf der Mahlseite nicht näher darauf eingegangen wird, wie man den Deckel entrastet, wird mir ein Rätsel bleiben. Für mich ist diese Anleitung überflüssig wie ein Kropf.
    Erwin Sokol (Winni) - crwdns2934203:0crwdne2934203:0
    Nicht so ungestüm: die Anleitungen bei iFixit sind mosaikartig aufgebaut. Die hier wird von mehreren anderen benötigt, alleine ist sie tatsächlich weniger nützlich.
    VauWeh -
    Ein paar Ergänzungen dazu:
    Das Bohnenfach vorher vollständig entleeren. Denn falls man die obere Abdeckung ganz anhebt, fallen die Bohnen aus dem Fach in die offene Maschine.
    Die rechte und linke Seitenabdeckung sind mit der oberen Abdeckung mittels Laschen eingeclipst. Dies kann man gut auf dem dritten Bild erkennen. Hier hilft es beim hochziehen der oberen Abdeckung mit einem flachen Blech o.ä. in dem Spalt zwischen Abdeckung und Seitenblech leicht hin und her zu fahren.
    PapaRepariertAlles - crwdns2934203:0crwdne2934203:0
  5. Disassembling the Saeco Exprelia, left panel: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the front access door.
    • Lift the top cover by about 2 cm until you can just reach the screw in the top right.
    • Remove the T10 Torx screw
  6. Disassembling the Saeco Exprelia: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the top cover slightly upwards. It requires a fair amount of force to push the side cover upwards by about 5 mm until the hooks are released and then lift it out.
    Leider kann ich das Bild nicht hier rein setzen. Werde es versuchen über bzw bei mein Account zu setzen.
    Armin Moll - crwdns2934203:0crwdne2934203:0
    Das geht nicht,weil die links unten an der Ecke blockiert .Da ein Stück der Abdeckung link noch vorhanden ist das die Blockade macht.
Work through the steps in reverse order to reassemble your device.
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
VauWeh
crwdns2935283:010/19/15crwdne2935283:0
256 497 crwdns2915208:0crwdne2915208:0
crwdns2935297:0286crwdne2935297:0
Repair is War on Entropy crwdns2935289:0Repair is War on Entropycrwdne2935289:0
Community
crwdns2931471:029crwdne2931471:0
crwdns2935297:01 778crwdne2935297:0
Hallo. Ich habe das Problem das ich die Antriebs Zahnräder der Brühgruppe der Saeco Exprelia HD8855 falsch eingesetzt habe. Kann mor da einer helfen?
Andre - crwdns2934203:0crwdne2934203:0
Zur Orientierung hilft vielleicht das hier: Saeco Royal Zahnrad im Getriebe austauschen, Schritt 23: Setze das graue Zahnrad beim Einbau so ein, dass die Nullmarkierung auf die Achse des weißen Zahnrads zeigt.
VauWeh -
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 145
crwdns2942667:0crwdne2942667:0 9,992
