Pop off the plastic back cover to reveal the battery. Use a fingernail to lift up the battery from the top side. Under, you will see the SIM card slot.
Using a Phillips screwdriver, unscrew the six screws holding in the back shell.
Use a spudger to wedge between the seam of the front and back shell, and wedge the back shell up.
The main board, which holds the button board and the screen can easily lift out of the front shell.
Remove the silicone button membrane using a finger or a spudger.
Congrats! You have made it to the end of this dissasemby. Now to assemble it back together...
crwdns2935229:091crwdne2935229:0
How do I get my security code for Nokia ta-1402 8 digits
Way phone number is not easy to get
