Disassembling Nintendo DS Lite Bottom Case
  1. Disassembling Nintendo DS Lite Bottom Case, Nintendo DS Lite Battery Disconnect: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place your device upside down and locate the battery compartment.
    • Find the Phillips head screw securing the battery cover in the bottom right hand corner of the device.
    • Loosen the screw enough to remove the battery cover but leave the screw in the cover for reassembly.
    • Use only a Phillips screwdriver to remove screw.
  2. Disassembling Nintendo DS Lite Bottom Case: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slowly remove the battery cover with the iFixit opening tool.
    • Make sure to remove the cover carefully to keep from losing Phillips screw in the cover. It will be needed for reassembly.
  3. Disassembling Nintendo DS Lite Bottom Case: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Nintendo DS Lite Bottom Case: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the iFixit opening tool to carefully pry the battery out of the case.
    • After the old battery is removed replace it with a new battery facing the same direction as when the cover was opened.
    • For some devices, you may be able to remove the battery by flipping the DS over and letting the battery fall into your hand.
  4. Disassembling Nintendo DS Lite Bottom Case, Disassembling Nintendo DS Lite Bottom Case: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following seven screws that secure the lower case to the DS Lite:
    • Three silver tri-point screws (5mm long)
    • One black tri-point screw (4mm)
    • Two gold Phillips screws (4mm)
    • One silver Phillips screw (3mm)
    • Do not remove the silver PH screw (3mm) in the battery compartment yet. It holds the main PCB in place.
    Remove the Tri-Wing screws from the DS cartridge port area and the battery bay.
    Matt - crwdns2934203:0crwdne2934203:0
    They left out of the tool section the Triwing screwdriver, a security tool used on most Nintendo game systems. There are 4 Trihead screws holding the case together and 3 Phillips head screws.
    ABCellars - crwdns2934203:0crwdne2934203:0
    I actually have Tri-Wing screws on mine!! You can't open the unit up unless you have the proper tools!
    Jon Fukumoto - crwdns2934203:0crwdne2934203:0
    why do they use tri-wing!?!
    Bountofee - crwdns2934203:0crwdne2934203:0
  5. Disassembling Nintendo DS Lite Bottom Case: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • On the front edge of the Nintendo DS between the headphone jack plug and volume controls remove the plastic insert (or cartridge) from the lower slot (Slot 2).
  6. Disassembling Nintendo DS Lite Bottom Case: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Nintendo DS Lite Bottom Case: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the unit over so that it is facing right-side up.
    • Use a spudger to pry open the gap between the bottom case and the front panel. Work all the way around the case until the panel is free.
    • Avoid touching the L and R shoulder buttons, because they easily detach and are difficult to reassemble. Keep the bottom case flat against your workbench to help hold the shoulder buttons in place.
  7. Disassembling Nintendo DS Lite Bottom Case: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Nintendo DS Lite Bottom Case: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Nintendo DS Lite Bottom Case: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully separate the two pieces by hand.
    • The two shoulder buttons are made up of three pieces -- the plastic button, a pin, and a spring. If they accidentally pop out while you are working, study the picture and make sure you put the spring in the correct position.
    • When reassembling the cover, make sure that the power switch caver on the bottom case is in the off (down) position to avoid breakage.
crwdns2935229:011crwdne2935229:0
Brittany K
crwdns2935283:001/21/10crwdne2935283:0
1.534 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 16-30, Maness Winter 2010 crwdns2935289:0Cal Poly, Team 16-30, Maness Winter 2010crwdne2935289:0
CPSU-MANESS-W10S16G30
crwdns2935297:029crwdne2935297:0
crwdns2947412:05crwdne2947412:0
Not bad tutorial but I want to complain a little bit. Could you add more flashlights when you take photos of dark objects? It would make this tutorial more pleasant for viewing.
Clayton Simpson - crwdns2934203:0crwdne2934203:0
Thank you my ds gave up last night and I want to open it and have a look 👀
Rom - crwdns2934203:0crwdne2934203:0
This tutorial worked great for me! My sons DS got wet and I was able to successfully open and dry it out. Cleaned up with alcohol and it’s running better than ever. Grateful for you!
Angela Schlagenhaft - crwdns2934203:0crwdne2934203:0
The tri-point Y1 screwdriver is not working for me. I have tried both Y000 and Y1.
Michael Sam - crwdns2934203:0crwdne2934203:0
Same, I just bought the Y1 triwing screwdriver here with a digitizer for the ds lite and the screwdriver is too big.
Ian Swift -
crwdns2936753:030crwdne2936753:0 199
crwdns2942667:0crwdne2942667:0 17,171
