Disassembling HP Mini 210 Back Case
  1. Disassembling HP Mini 210 Back Case, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling HP Mini 210 Back Case, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn off and unplug the netbook before replacing the battery.
    • Hold the netbook top-side down with the lid closed.
    • Slide the plastic battery release latches towards the lock symbols.
    • The left tab unlocks completely, but you will need to hold the right tab towards the lock symbol as you remove the battery.
  2. Disassembling HP Mini 210 Back Case: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the battery out from the netbook.
  3. Disassembling HP Mini 210 Back Case, Disassembling HP Mini 210 Back Case: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the netbook to view its edge.
    • Press both orange eject buttons simultaneously, and use a spudger to pry off the back case.
  4. Disassembling HP Mini 210 Back Case: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If the back case does not separate from the netbook easily, use the spudger to pry off the back case by the edge near the battery compartment, and work your way to the sides. The case will then pivot along the front edge.
  5. Disassembling HP Mini 210 Back Case: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the back case off from the front edge.
crwdns2935229:012crwdne2935229:0
Heather Freed
crwdns2935283:010/06/12crwdne2935283:0
723 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 9-17, Amido Fall 2012 crwdns2935289:0Cal Poly, Team 9-17, Amido Fall 2012crwdne2935289:0
CPSU-AMIDO-F12S9G17
Gracias!! esta guía fue muy util
Tony Ortega - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 36
crwdns2942667:0crwdne2942667:0 21,443
